67 Single cab
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
67 Single cab
Ok, maybe in the wrong section as this will not be a restoration project but neither will it be a Sean like, weekend wonder
So let me officially introduce the the car. He has no name(yet) but is most definitely a he...bakkies just are.
- Eugene
Re: 67 Single cab
As per the subject line, it is a 1967 Single cab. It has been in one family since new. It has always been a "plaas bakkie" and was only ever registered on the road, for the first time in 1994 by the now, previous owner and grandson of the original owner. It is a 50 year old, unmolested work horse, now retired. As I said, I will not restore it but keep it as is and do my best to retard the natural ageing process. Also fix the current issues, like fuel tank and fuel lines, fuel pump, brakes and steering. The engine was running but due to rusty, very crusty fuel tank, the fuel lines were blocked, fuel tank leaking and fuel pump faulty.....all related I believe. The PO then fitted an electric fuel pump and ran it off a fuel can
- Eugene
Re: 67 Single cab
The fuel issues were all caused by this. Water and dirt enters this area...accumulates over time causing rust.
The tank was shot, with so much shit inside, I thought it was half full of fuel. Once the covers and tank was removed, the consequences of the small opening left unattended was clear
This all came out
Unfortunately, I did not take "after" pics but the area was cleaned, vacuumed and then treated with rust converter. The load bed will be welded closed again to prevent a repeat.
This all came out
- Eugene
Re: 67 Single cab
In the mean time, I fitted a new fuel pump and got rid of the electrical pump and incorrect diameter fuel line. Unfortunately, the old metal line is so blocked, I could not even clear it with compressed air, so I will replace that as well. With the new fuel pump in place, the little engine starts up immediately and purrs like a kitten. Unfortunately, the exhaust is also moertoe and will be looking for a replacement.
https://youtu.be/gYx9OT2ea80
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Re: 67 Single cab
Lekker Eugene !! Is die fuel lyn wat jy kort vanaf die pomp na die carb ?
- freddiebooysen
- Been thanked: 47 times
- Been thanked: 541 times
Re: 67 Single cab
You will pay anything to get something safe to stand on to look over the fence...........
Nice buy, good luck with the stepladder....... sorry ... should read Van.... now where is the erase button again.....
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: 67 Single cab
Hey Uncle
Pay attention, forget about granny ghia on the other side of that wall.
Yours is easy. I think I took a entire 2 weekends to get this one rolling.
But I think we can allow an extension until Feb, George 2018. Then you can roll with these 2.
I crave a road trip in a patina bus again.
- Eugene
- sean
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Re: 67 Single cab
Now I thought you wanted to take your Autovilla to George after last year's rained out affair, leaking tents and all ???
You could also use your nice Jurgens teapot and cups and saucers.
Very nice single cab Eugene !!!!
- sean
Re: 67 Single cab
Yes, correct sir, never again will I sleep in a tent. I will take the patina busses and I'll just make sure that my other half takes an autovilla. Then I can sleep comfortably and have dinner off all that superior Jurgens crockery.
- Oil Cooler
- What model do you have?: 69,75split,75,79scab
- Has thanked: 85 times
- Been thanked: 16 times
Re: 67 Single cab
Lekker wa daai Eugene
61 Beetle aka klapperkiste
68 Squareback viewtopic.php?f=23&t=34408
69 Kombi
72 Crew cab viewtopic.php?f=23&t=32846&hilit=1972+custom
75 Fleetline panel viewtopic.php?f=23&t=32485&p=309053#p309053
79 Single cab
69 Kombi
79 Single cab
