Beetle 75 misfiring
Stewardt
Beetle 75 misfiring
Post by Stewardt »
Hi Im new to ACVWSA. I recently bought a beetle 1975. Happy chappy bout the car, but have only one issue i can't address. The car starts perfectly first time. Then after switching it off it sounds like its missing fuel. I've googled and the best answer i could get is Vaporlock. Any advice pleeasseee
Re: Beetle 75 misfiring
If this is after you have turned off the key, it is pre-ignition.
The VW carb has a electrical solenoid on the carb that prevents this, so maybe the wire is off or it is shot.
This is not dangerous but unsettling.
Just put it in gear and let out the clutch the motor will stop.
This is due to the heat, normally in your spark plug electrode or the carbon in the chamber that ignites the fuel as it comes in without the ignition firing.
You can change the spark plugs to NGK BP7HS or NGK BPR7HS or fix the shutoff solenoid in your carb.
If this does not stop it, then your engine is overheating, look at all your tins in place and all open holes closed off, and engine rubbers in place.
Stewardt
Post by Stewardt »
When i switch the car off and try to start up again it does that. But when i leave it for a long period of time it starts perfectly again. So i think something happens when the engine is "hot". Because as soon as it cools down, or in the morning when i start up the first time, everything works perfectly.
