Hi All,
Fitted another dual set of carbs with lower manifolds
Connected all wires from coil to both carbs
Just running on piston 1 & 2
Manifold of puston 3 & 4 “cold as a lady of nights heart”
There is fuel when I open the throttle
What will the reason be ?
Firing issues !!
Re: Firing issues !!
plug wires the wrong way round?
blocked idle jets
idle solenoid closed
unbalanced carbs
idle mixture adjuster screwed all the way in
vacuum leaks
blocked idle jets
unbalanced carbs
vacuum leaks
