Front hub nut
- What model do you have?: 72 beetle
Front hub nut
Hello just need to know what size the front hub nut is on my beetle would it be the same at tbe one in the back 36mm in my but my car and i forgot to look this moring lol
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: Front hub nut
No they are not the same. The front hub is fastened with 2 fine threaded nuts on each side with a lock washer between them. The left-hand side has an opposite thread. The inner nut tensions the front wheel bearings, while the outer nut locks everything in place with the lock washer. The inner nut takes a very low torque, literally a fraction more than hand tight. If you overtighten your front hubs you will quickly wreck the wheel bearings.
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Re: Front hub nut
Front hub nut is 27mm
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Front hub nut
You don't have to replace the nuts to change the wheel bearing. I doubt you will be able to find the correct nut at a nut and bolt shop. Its a very fine pitch, but more difficult to find is the width of the nut. As Fig also mentioned, remember the one side is reverse thread.72BugMan wrote: Thu Feb 01, 2018 10:09 am Oh ok thanks cuase ive gotta do my front left wheel bearing
Re: Front hub nut
Yea im not changing the nut i just need to know the nut size so i can bring the tools hone from work to change the wheeel bearing tonight lol
- fig
- Bus Driver
Re: Front hub nut
In that case you will need 2 thin 27mm open spanners.
Ideally you should replace the lock washer with a new one but, since they're not easy to find, best be very careful when you straighten out the old one so you can reuse it.
- Has thanked: 141 times
- Been thanked: 100 times
Re: Front hub nut
One thin 27mm open spanner for the inner nut and a shifter for the outer works for me. Also, a new lock washer is supposed to come with the front wheel bearing kits. I always get one.fig wrote: Thu Feb 01, 2018 11:10 am ... you will need 2 thin 27mm open spanners.
.. since they're not easy to find, ...
