BAYWINDOW 2.0 EXHAUST MANIFOLD PIPES
Jack Nel
What model do you have?: 1976 T2 Baywindow
Post by Jack Nel »
What is the best way to go about replacing the exhaust manifold pipes which joins to the silencer on my 2.0 Baywindow?
Should I try and order from one of the aircooled suppliers or maybe even import or will someone like Powerflow be able to make them up, what will be most economical and sensible?
Your advice please
spicydave
Oil Seal
What model do you have?: 1973
Has thanked: 7 times
Been thanked: 15 times
Re: BAYWINDOW 2.0 EXHAUST MANIFOLD PIPES
Post by spicydave »
@Sean
Madbones
What model do you have?: 182 Thing
Has thanked: 12 times
Post by Madbones »
Hi Jack,
If you find a good solution I am also looking for a new pipe for my 2L Autovilla.
I believe a good flowing pipe will give us a few more pips :hangloose:
Regards
Madbones
Been thanked: 539 times
Madbones wrote: Tue Mar 20, 2018 11:48 am Hi Jack,
Regards
Madbones
PowerFlow would be your best option, as they make them up as you wait, with Stainless steel.
Or you can go to an Tuffex dealer, they normally carry VW aircooled exhausts in mild steel or S/Steel.
Both have given me good service.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
I have a after market exhaust on my Early Bay 1600 and I just love the noise of it.It has 2 tail pipes and was made by TNT Germiston heard they where closing then they are not so best to call them.They are still going R2500 fitted so loose set will be cheaper.I can post a picture of my system if needed.
Been thanked: 487 times
2L engine is very different to your 1600 Terry.
Cowley has "performance" systems on the shelf for the 2L, but it starts where the heater box ends, not at the head.
If you want it made from the head, then you'll likely have to make the stubs yourself before anyone will make the rest of the header
Terry Phillips
Zambia
Oops not reading to good sorry must be brain fade again.
Jack Nel
Post by Jack Nel »
Thanks everyone
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
There are no heater box replacements locally for the CJ or CU 2.0l motors. You can import, but it will probably cost more than R15 000 for a set.
You can however fabricate a header out of tubing (no more heating system) utilising the cast fittings from the old heater box. The cast inlet ports on the heater box cant be replicated as its a casting, but the old pipe and heater box can be cut off and new pipes bent up to the flange. Any decent exhaust shop could make these up.
Silencer replacements are available in standard form and 4-1. This bolts onto the flanges at the end of the heater boxes.
Madbones
Post by Madbones »
Awesome thanks for the info.
Madbones
