1972 Crossover D/C - Blue Abomination
Eugene
Has thanked: 59 times
Been thanked: 65 times
Re: 1972 Crossover D/C - Blue Abomination
Post by Eugene »
With the color coded wiring diagram and some common sense, you'll be able to do it yourself. get proper crimptool, automotive wire and lugs and Bobs your uncle
freddiebooysen
What model do you have?: 1972
Been thanked: 47 times
Post by freddiebooysen »
Eugene does that neighbor of yours not do wiring ?
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Freddie, I'm with the others on this one. Do It Yourself! From what I know about you through this forum, you are more than capable. Something that works for me is to use a piece of heat shrinking to cover joints when you extend existing wires. Just remember to slip the heat shrinking over the wire prior to soldering! I forget most of the time.
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
NICE FREDDIE!
SO WE'LL SEE YOU SOON THEN?
freddiebooysen
Ok guys.
Looking for a dipstick for my type4 1700 baywindow Bus any available ?
freddiebooysen
So finally she is driveable well sort off struggling with the gears still but will follow the advise earlier and see if I can get it sorted
First fill only R 200
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Thats a nice sight and at the pumps means you are going places.Good luck on the test drive hope all is good.
freddiebooysen
Going home yes that is a place a suppose.
Took almost 2 years to get to this point and damn I struggled with the gears!
Figured I will try sort out the gear lever shafts etc
And start with the wiring still lots and lots to do here but excited nonetheless
Has thanked: 191 times
Been thanked: 487 times
Well done. Progress indeed.
Nearly time to begin enjoying her
freddiebooysen
So some work needs to be done
So main plan is to start some light body work and obviously the wiring.
Even though there is an alternator fitted it is not charging and figured I must start here since I need to make sure battery charges so I can work on the wiring
Any suggestions on getting this one rebuild vs buying a new one if there is still available
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Hi Freddie
Check the external regulator first, I have found them to be the first issue before an alternator.
The type4 alternator is not available locally. If it is suspect, it may be brushes or diodes. They can be rebuild.
Has thanked: 42 times
Been thanked: 207 times
Post by Dawie »
Is the warning light coming on with ignition turned on?
freddiebooysen
Well guys the alternator is not connected at the moment to anything.
Need to start from scratch.
Are you talking about the oil warming light ?
Eugene
Post by Eugene »
Hey Freddie...start here. AVO meter and this printed out in color on A3 and Bob's your uncle
https://www.thesamba.com/vw/archives/in ... s_8_71.jpg
Post by Dawie »
No, talking about the "gen" warning light. Your alternator will not charge without that globe connected. An alternator, unlike a generator, is not self-exciting. It needs the tiny current provided by that globe to start a tiny magnetic field.
