I went shopping today, I got:
2.5l gearbox oil 80w90
2 Axle boots
Oil pressure sensor (Wrong one)
17mm hex bit for the gearbox drain plug
Some RTV gasket maker
Spade terminals
Chinese carb from Midas - surely not the best but can only be much better than what was on there and at R1000 is worth the try ???
IMG_20180630_142718 by B R, on FlickrSo I am all excited when I get home with all my goodies today, push the baja into the garage to fit the carb and the thing won't fit. The mounting holes don't line up. They are slightly wider on the the carb than on the intake manifold. is that a 1300 vs 1600 intake thing? this is a single port machine.
Anyway I can't sit still so I decide to make an adapter so I can at least see how this carb runs ... I spend the rest of the day doing that and now it is too late to make too much noise so I can only try start it tomorrow. I have no idea how many cc's this engine is so hopefully the jetting is not way off.
First I traced out some templates then got to cutting and shaping some stainless steel I had lying around... it's not perfect by any means but it looks like it will work.
IMG_20180630_150953 by B R, on Flickr
IMG_20180630_151659 by B R, on FlickrI also cut some new thicker gaskets to go with my adapter because the stainless warps so much when welded that the mating surfaces aren't perfectly flat. I added some gasket maker to the thick gaskets as well to help a bit more with that.
IMG_20180630_182331 by B R, on FlickrThis is how it all turned out:
IMG_20180630_184150 by B R, on Flickr
IMG_20180630_193314 by B R, on Flickr
IMG_20180630_195429 by B R, on FlickrNow I just need to find out if that other spade terminal on the carb needs a neg or pos wire to it, my gut says positive like the choke....???
