Cylinder head temp gauge
Has thanked: 425 times
Been thanked: 543 times
Re: Cylinder head temp gauge
Tony Z wrote: Wed Jan 23, 2019 7:41 am not entirely true Herman, your oil can be fine while you are melting the heads (lack of cooling, dirt in fins, too lean AFR...)
OK, If we split hairs, yes, you will have a deviation on an hotted up engine, and if you have an true temp. output, you will find that he temp fly's up on piston fire, and cool's down on fuel intake, cools when going under a tunnel, and heats when in full sun.
These are things that the normal VW aircooled guy has very little use for. If you have a normal or slight mod air cooled, and you measure the oil temp. you will find the average effect that the oil gives to a temp. meter reassuring, as one does not want to have a hart attach every time you hit the gas.
You will see the temp clime on hills and drop down hill, you will even spot well in time if the fan belt breaks,
So Yes, for the boy racer that wants a aircraft cockpit of gauges, then yes, go for it, but the normal guy like SEAN, oil temp. will serve you well.
splitfan wrote: Wed Jan 23, 2019 11:32 am Agree with Tony , I used these on the big bore type4 motors as we all know they love to drop a valve seat if the heads get to hot :(
If your seat has been fitted correctly, it will not come out on heat. Your oil will fry before the guide comes out.
Your engine can take more heat then your oil can before causing damage.
once again, only my opinion, and not wanting to start a bun fight.
I bow out..... :wink:
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
No man, no heat gauges. You have in oil pressure light. If it comes on, you are stuffed. The rest of the time is always good.
headworks#1
What model do you have?: 2275cc B BUGGY
Been thanked: 7 times
Post by headworks#1 »
Yes agree with all above comments. This is not for the purist but if your Big bore motor cost above R100k, you want to be sure what is going on. Had this situation once oil temp and pressure fine and cooked head only 4km down the road partially blocked main jet on one of the twin carbs. there is a saying in Afrikaans om te meet is om te weet.
