Old engine spec help needed
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Hi guy's
Need help on this engine, # 3850299, it's currently in a 70's bug, anyone that can help me with spec's on it?
Thank you in advance,
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 321 times
Re: Old engine spec help needed
I can't see the pics, but that engine number dates from May 1960, so would originally have been a 40hp 1200.
- Has thanked: 42 times
- Been thanked: 207 times
Generator pedestal part of casing. Fuel pump mounted on the side.Thats an old 1200, sometimes incorrectly referred to as "1100".
As Fig say, early 60.
- Bratjie
Any worth to it? running condition except for genny and regulator not working? Would this still be a 6v generator then?
73 Beetle project
73 Beetle project
- Been thanked: 539 times
without opening it, you will not know.
It could be standard or it could be a 1835 or 1914 you will not know, as these old engines have always had fingers in them over the years.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Those smaller generators were 6v only, unless from a Porsche. I suspect this car was running on 12v and has now damaged the generator and regulator because of this.
This is a 30hp 1200, as others mention, often referred to as 1100. It is not possible for this engine to be 1835 like retro van is referring too, not possible.
If it was fitted to a late beetle, it would have had no power being fitted to the incorrect ratio gearbox. Shame.
Only a select few would be interested in those motors, not much desire for them these days.
I would be interested in it should you want to sell.
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
yea....he's doing you a favor here
- Bratjie
He he he like a 15k favour, lol!!!!
73 Beetle project
73 Beetle project
sean wrote: ↑Fri Feb 01, 2019 6:02 am ......... It is not possible for this engine to be ... anything but stock... as no body would have the guts to modify anything ..., not possible.
If you have X-ray eyes you would know that it is stock, and just what Sean needs...
Nearly got it, Hey Sean.....
Pre-60's vw engine, dimension wise, dont have much in common with later type 1 engine. Bores spaced much closer together, shorter crank. After careful machining, largest bore possible somewhere around 83.5mm i think. 92's wont fit.
Thanks Dawie,
I totally agree with you, was only using an example of how probable it will be that the engine may not be standard.
The 2nd post was just to pull uncle Sean's socks....
But the point I am trying to make is that without opening it you not sure what you find.
Like on Gumtree when you get an add that says " running well" you know its due for and rebuild.
- Jdt1976
- What model do you have?: 1952 beetle
- Has thanked: 114 times
- Been thanked: 90 times
The number on the side of the generator would tell you what date the block was manufactured so you can check if the engine number is original to the block.
Day, month, shift and year.
18 5 23 would be 18 May (second shift) 1953
Another number (for the other case half) is located near the oil pump.
The two sets of numbers should not differ by much if they not the same.
