Gasket set
- Has thanked: 193 times
- Been thanked: 121 times
Gasket set
Can someone tell me if the gasket sets for a 1600 single port is the same as the Twin Port motor.
- Oil Seal
- Has thanked: 13 times
- Been thanked: 9 times
Re: Gasket set
When you buy a gasket set it has both the twinport and single port gaskets. AFAIKTerry Phillips wrote:Can someone tell me if the gasket sets for a 1600 single port is the same as the Twin Port motor.
Sent from my FIG-LX1 using Tapatalk
- Oil Seal
Re: Gasket set
Quite fairTerry Phillips wrote:Thanks Jono is R228 a fair price its a decent brand.
- Has thanked: 191 times
Re: Gasket set
I import white silicon pushrod tube seals, R175 per set
I've had brilliant success with these
- Has thanked: 4 times
- Been thanked: 98 times
Re: Gasket set
Ditto Tony
Got genuine German Elring gasket sets R490.
Re: Gasket set
Came from Germany via USA, no main seal.
