"Eva-Ann"
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Re: "Eva-Ann"
Post by buggyfan »
:roll: Measure twice..... Cut once :roll: :roll:
Batman
What model do you have?: 1971 Beetle 1600 TP
Re: "Eva-Ann"
Post by Batman »
Cut some new door cards yesterday ...
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: "Eva-Ann"
Post by Terry Phillips »
Thats a step closer now keep the pictures coming in. :D
Camshaft
Been thanked: 107 times
Re: "Eva-Ann"
Post by Haans »
Looking good!,.....now try thecovering ,,....if younot to fussy with detail patterns,..youcan do it also.
Just take your time!,....and try the glue in a spraycan,.....seem to work well
Oh!!,...keep the car out the sun for at least a week once cards are fitted,....they say the glue must cure!!
Batman
Re: "Eva-Ann"
Post by Batman »
Haans wrote: Fri May 03, 2019 11:04 am Looking good!,.....now try thecovering
Luckily i'm going to get it covered by an upholsterer
Batman
Re: "Eva-Ann"
Post by Batman »
Batman wrote: Mon Dec 10, 2018 7:27 am The previous owner rubberised the interior for some reason. I thought that it was still in a good condition and that I would just clean it out and I would carpet over it.
But the weekend with some closer inspection I realised that it was lifting and that the one door is leaking, causing water to build up between the rubberising and the floor-pan.
Glad to say that all rubberising has been removed. Now sanding and then some paint......
Batman
Re: "Eva-Ann"
Post by Batman »
Some before work in progress photos.
Riaan.N
Oil Seal
Has thanked: 3 times
Been thanked: 38 times
Re: "Eva-Ann"
Post by Riaan.N »
Also recently done the areas under the front and rear seats.... it looked as if the battery had a baby powder party
What size is the Willard battery you have?
Batman
Re:
Post by Batman »
Riaan.N wrote: Fri May 24, 2019 10:19 am What size is the Willard battery you have?
647
Riaan.N
Oil Seal
Re: "Eva-Ann"
Post by Riaan.N »
647
Thank you. Does it fit nicely? Do you use the original bracket and ‘dop’?
When the time comes I will be replacing my battery with something a bit bigger (Ah) and also if possible with the recessed terminals.
Batman
Re: "Eva-Ann"
Post by Batman »
Did some cleaning the weekend ... and cut a new rear seat backboard
Batman
Re: "Eva-Ann"
Post by Batman »
Got some widened steelies for the rear ....
Batman
Re: "Eva-Ann"
Post by Batman »
Sorted prepping the pan ....
Riaan.N
Oil Seal
Re: "Eva-Ann"
Post by Riaan.N »
You are making good progress and have put in a lot of elbow grease! :D
How was/is the condition of the pan halves?
Batman
Re: "Eva-Ann"
Post by Batman »
Riaan.N wrote: Fri Jul 12, 2019 2:44 pm You are making good progress and have put in a lot of elbow grease! :D
Pan is actually good, just the usual part where the battery is, is a bit rusted. Will cut it out and replace the small section.
Must say a lot of elbow grease :D ... was a mission to get the rubberizing removed.
