I have the following used VW aircooled bits and pieces for sale.
Bosh H4 Beach buggy head lights R500.00 for the pair.
Working Beetle starter motor R500.00
Beetle engine stand R500.00 (Sold 10 times over)
Split bus Side-shaft/reduction box, gear leaver, hand brake lever and steering box R1500.00
Puma air intake manifolds and one Solex 40/44 carburettor R1000.00
Beetle 1500/1600 single port head R500.00
Beetle flywheel, pressure plate and 2 x clutch plates R250.00
Aircooled bits and pieces for sale
- VW-rules
- What model do you have?: 1961 Bus
- Has thanked: 10 times
- VW-rules
Re: Aircooled bits and pieces
More pictures of the bits and pieces
Re: Aircooled bits and pieces for sale
If Riaan doesnt want the engine stand, I'll take it
- VW-rules
Engine stand, Flywheel & Clutch sold.
- VW-rules
Re: Aircooled bits and pieces for sale (Items added)
Early bay bus rear wheel hub swing arm torsion bar and spring plate
Bay bus rear wheel hub swing arm torsion bar and spring plate
Bay bus complete front beam, wheel hub and disk brakes (Ideal for a front disk brake conversion on your early bay.)
- Oil Cooler
- What model do you have?: a few
- Been thanked: 4 times
hi vw - rules
I would like the , if still available
rear split bus shafts/reduction gears x 2
early bay rear hub assembly x 1
Price pls ?
Price pls ?
