Yesterday while driving in the rain with headlights and wipers running I noted my generator light came on dimly and then noted a burning smell coming from somewhere. I killed the lights immediately and drove a bit further and tried the lights again and all was good. Generator light stayed off.
Tested the battery voltage this am and 12.8 V. Started up and tried the lights and then noted the voltage sometimes dropping for a few seconds right down to 10 and then back up to 13.8 without me turning the lights off. I see a small resistor wire at the back of the regulator that has the signs of getting warm as the bakelite mounting looks a little discolored/melted. Is it probably the regulator that needs replacing ?
Sent from my HUAWEI VNS-L31 using Tapatalk
Voltage Regulator - Beetle
- No More Landy
- Has thanked: 23 times
- Been thanked: 6 times
- No More Landy
Re: Voltage Regulator - Beetle
So I did a quick test drive with my multimeter plugged into the small oil pressure gauge lamp circuit and drove around the block. When I drive with the park lights on I read up to 14 V at full revs and idles at 12.8. After putting on full beam the volts drop to 11 and don't recover much more than 12.5 V after I drop to dips.
When I stopped and checked at the battery itself and held the meter hard against the terminals I get 13 V on idle and max 14V with slight revs, and when light's on normal beam she sits at 12.9V at idle and slight revs at 14V. Seems there is a drop in the wiring somewhere as I know all my earth straps are good as I did them all a short while back. Bit stumped now.
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- No More Landy
Just realised my mistake, the lamp circuit for my gauge goes via the resistor in the headlight lamp dim switch for the instrument lamps.
Idiot !!
Idiot !!
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Been thanked: 539 times
Sounds normal to me
Could just be that your battery was very low on charge putting a big load on your voltage regulator.
- No More Landy
Thanks Herman
Did another test run with my meter connected this time to my oil pressure gauge +&- terminals and all seems good. Headlighs on full I get 13.8V and when idle it drops to 12.4V.
Headlighs off she hits 14.4V while driving and also 12.4 @ idle.
Can it be that the rain through the boot lid breathers wet the alternator which I see is open at the top and caused a problem last night and now is fine?
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Pushrod
- Has thanked: 141 times
- Been thanked: 100 times
- No More Landy
Not sure, I don't know the difference.
1971 Beetle
2021 Polo tsi
2021 Polo tsi
I think you had the lights on with the engine off or your battery not the best, but this is what happens when the battery is discharged, and the generator has to work hard to get the battery full and keep the lights on at the same time.No More Landy wrote: ↑Tue Jul 30, 2019 2:00 pm .................Can it be that the rain through the boot lid breathers wet the alternator ...........
The charge light is directly connected to the battery well being, and if its not on voltage the light will glow dull, till the battery gets to voltage.
- No More Landy
The battery is at full charge as I left it on the C-Tech while I was away and have been driving her all week without issue. Seems more moisture related, maybe a short in the headlamps but I think that would have blown a fuse first ?retrovan wrote:I think you had the lights on with the engine off or your battery not the best, but this is what happens when the battery is discharged, and the generator has to work hard to get the battery full and keep the lights on at the same time.No More Landy wrote: ↑Tue Jul 30, 2019 2:00 pm .................Can it be that the rain through the boot lid breathers wet the alternator ...........
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Pushrod
AFAIK alternators can charge at idle speed but generators need a bit more revs, 2000 I think. Not directly related to your problem but it wouldn't hurt to replace your generator brushes. My '71 beetle's generator light was forever flickering at low revs, making me doubt whether it was operating properly. I replaced the points based voltage regulator with a solid state one and replaced the brushes. All is fine now. I found that the brushes are not that commonly available locally and was lucky to find a pair at Goeie Hoop Onderdele.
