Morning all,...I have come accross 12V flywheels with an O-ring in the centre on the crank side.
Removed Haans's flywheel,....still 6V starter ,....and no O-ring???
Should I put one back?
What is the purpose of it?
Your speedy response will affect the the assembly time!!! ......ie eagerly awaiting a response!
Regards Haans
6V flywheel ?? O-ring ???
- Has thanked: 42 times
- Been thanked: 207 times
Re: 6V flywheel ?? O-ring ???
Think late type flywheel had a groove that take the o-ring.
Early type had thin gasket. Critical to maintain correct end play while preventing oil from leaking through.
- Camshaft
- Been thanked: 107 times
Thanks Dawie,....it seems there was particals of a thin paper gasket,.....did not see a visible "groove" for an O-ring.
So it seems that this engine needs only a paper gasket ?
What say the rest ?.......just spreading the net a bit wider.
Regards Haans
Regards Haans
- Has thanked: 191 times
yip, only the gasket
- Camshaft
Found paper gasket in kit,.....in and torqued up
Monday,.....into car,....then all tins and plumbing
Thanks guys,....Haans
