Box jumping out of 4th?
Camshaft
Been thanked: 107 times
Post by Haans »
Ok,...done the bush and link in the rear,...mounting is perfect,.....adjusted it to moer and back,......still doing it
Suspect the slider/ syncro thinghy between 3rd and 4th to be the problem,......according to aunt Google??
Now, I understand that the gear pack can be removed and this ."thinghy" can be replaced, But you need specialised tools AND skills. Is this a fact?
Talk to me
Regards. Haans
Been thanked: 539 times
Re: Box jumping out of 4th?
From the experience collected from my Bay Bus gearbox saga, and the slipping out of 4 gears I can say its due to;...
The thinamabobs in your watsemecall it, is not wattever into you know.
This means that no matter how you giggle it by dingising it you will not get it to what ever, you know what I mean ??.
so my wife''s diagnostics need to be translated.
So to put it in VW volks words, its not locking into the gear and you need to remove the box and send it to Bugger transmissions.
Its a gearbox thing, not a setting thing.
Been thanked: 321 times
Haans wrote: Thu Sep 26, 2019 8:40 amBut you need specialised tools AND skills. Is this a fact?
This is unfortunately true. The first thing you need is the appropriate jig to set all the clearances on the bench before feeding all the gears back into the box. Anyone can obtain one of these. The second thing you need is EXPERIENCE. Those who have tried to set up a gearbox, using the correct jig, and who have then assembled the whole shebang and reinstalled it in the car, only to find the box jumps out of one or more gears, will agree that this is a task best left to people who do it every day.
Camshaft
Post by Haans »
Ok thanks for all the advice,....leave it to a "pro",...
In the mean time we purchased another box!,....probably the more sane option.
Haans wrote: Fri Sep 27, 2019 3:12 pm Ok thanks for all the advice,....leave it to a "pro",...
Yes ..... unless the PO sold it for the same thing....... :shock:
Test it 1st ....Good luck
Camshaft
Post by Haans »
Ok !! Person is close friend !!! But that can change too,...he promised to help fit the box,..for free
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
I would rather have sorted the issue out with the original gearbox. As there is no way of knowing the condition of a second hand box, you will be doing all the work over to just find out its also got issues. You may get a lucky packet and its alright, but chances are slim. Old vehicles getting stripped for parts are not well looked after examples....
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
I don't know vw boxes but in general we would check the selector spring and ball, some times we would just put a new spring and ball in or a stronger spring I am not saying its the solution it might be a bigger problem but worth looking into. My2c
Camshaft
Post by Haans »
Thanks to all's input .....will let you know when and what came out of this lot
So have you sorted the Box by now
If need be you can send the Box up to me in Jhb and i can recon the Box for you 0826008663 Pierre
Camshaft
Post by Haans »
Thanks Pierre,...problem solved,..."....vehicle sold " as is "
Regards Haans
Pity you sold
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Haans wrote: Fri Nov 08, 2019 7:46 am Thanks Pierre,...problem solved,..."....vehicle sold " as is "
So Haans, now you can help the new owner and forward him/her Bugger's offer to sort out the box.
Camshaft
Post by Haans »
Note: not the ghia !!!
