With a ton of research, I have two possibilities.
The Giga Tech Conversion keeps the points and replaces the condenser. And an option the Auto Style sells is a conversion kit that replaces the whole lot.
What is the better way to go? Please see the images of both for reference.
Also, do I actually go ahead either way. The original Coil/Condenser/Points system is unreliable but easy to diagnose and fix, especially if you are on the road. If something goes wrong with the electronic route... It is not as easy to have a spare... Or is that reliable that I do not have to worry about having a spare?
