Help rescue a Bay Camper - please
MarshallGTi
Camshaft
Has thanked: 7 times
Re: Help rescue a Bay Camper - please
Post by MarshallGTi »
I cannot hear the engine over the whining gearbox
hahahaha
Ryan Marshall
3250
Has thanked: 423 times
Been thanked: 542 times
didi wrote:............. as I cannot hear the engine over the whining gearbox.
Another job for bugger................... :shock: :wink:
didi
Been thanked: 37 times
Post by didi »
I swapped gearboxes around today to see if my 72's is better. The mountings and rear bell housing is different. Had to use a different starter and swop the studs in front to make the mounting fit Image
Also saw why the gearchange is so sloppy. A garden hose mounting is not the same as the real thing :-)Image
_______
didi
Post by didi »
The other gearbox is fitted and the howling sound is something of the past. Also connected the oil temp gauge and sensor
I am battling to select 2nd gear though. Will have to figure out what is wrong there. Any suggestions?
_______
May have to reset your gear lever.
Put the gear box into 2nd, and loosen the bolts on the gear lever, hold the lever to the left, against the stop, and nip up the bolts.
should be OK, if not, repeat......
didi
Post by didi »
Thanks Herman, getting 2nd gear, now to find 1st!
Also trying to fit a rev counter to look stock. Here is a mock up I did last night.Image
_______
didi
Post by didi »
And here is it working. :-)
Cleaned and re-greased the gear leaver selector plate, still battling with finding the gears. All I can think of now is to replace the plastic bushes on the linkage. Any suggestions?
_______
Looking good Didi. Did you have to clearance the hole for the tacho? I did not want to do that to mine, but now that I have a few extra gauge clusters, I'll hopefully get round to mounting mine properly one day.
Now you just need a white needle for the tacho.
didi
Post by didi »
No clearance needed. It was a straight bolt on. I had to fabricate a bracket to hold it though.
_______
didi
Post by didi »
Was at Werner Alker today and he helped me to sort out the play on the gearleaver. He made this grommet/guide tube because mine was worn out. The difference is unbeleavable
3152
We also fixed the play on the steering and got the heaters working. (funny how quickly those can be sorted in the winter) :)
_______
didi
Post by didi »
New kick panels from a forum member and a parcel tray
_______
didi
Post by didi »
Muds posted me this radio. The hacked dash is now concealed and I have music in the bus :hangloose:
It took me a while to feed the wires through the A pilar and drop the wooden rooflining but it was all worth it.
_______
8) looking good, so many bay window dashboards have been butchered when newer radios were fitted - cool parcel tray, did you make it ?
didi
Post by didi »
Jolas, I bought the parcel tray from Kevi in Centurion. He brought in a bunch of stuff somewhere in last year, mainly for split busses but I managed to get this tray and some door pockets. Kind of handy when you are drinking a Coke. There is nowhere to put it when you are driving. :drunks:
_______
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
What a save, we hope you and the family will get many years of joy from her/him,good job well done by all involved.
I get my 69 high roof camper tomorrow , I have a T25 camper but I think the T2 will be special as it has its own character.
It is complete but needs work so I might have to ask you and others for some assistance and advice on where to get spares and how to do some restoration etc.
This is a perfect example of the enjoyment of owning and working on your own project and it must have been very rewarding for all involved.
Great job.
