My 181 - Kubel - Trekker - Thing
- Dutch_Diver
Re: My 181 - Kubel - Trekker - Thing
Nice car....what colour you going to finish with?
- Tom Bishop
- Single Port
- Been thanked: 5 times
Its going to be Yellow.
Working on the chassis, we found the seam between the upper and lower part of the tunnel has started to separate. I am not talking about the floor pans but the actual tunnel itself.
Well it will have to be welded up. Best I found it. You would not want the tunnel to fall to pieces in some remote part of the world.
Cheers
Cheers
- Tom Bishop
- Single Port
Chassis is comming along slowly. Should have it back by the end of next week. I know this has been discussed before - should it be stone chipped or painted with 300 line. what are the pros and cons.
- Tom Bishop
- Single Port
The PO told me this Kubel (oops 181) was fitted with a Limited slip diff from the factory. Other than stripping the box to find if this was true or not, I found this. It is the gearbox filler plug.
Now it stated I must use a special oil. So what oil must I use. Help Bugger
Got the chassis back this morning. All nice and black again.
First part in its place. All nice and clean.
What did you use on the chassis to make it all nice and black again?
Bad Ass Bob
- Tom Bishop
- Single Port
Stone Chip made it black.
And its shine on both sides not only on the top bab.
Bad Ass Bob
- Tom Bishop
- Single Port
Me to.
- Tom Bishop
- Single Port
Front suspension hanging and rear torsion bars in.
Now what is the official degs that the rear trailing arms must lay at before being lifted into position.
Cheers
Cheers
- Tom Bishop
- Single Port
Found out that the spring blades of the 181 must be 27deg in the rest position.
Yesterday I managed to to tighten all the front suspension bolts and assemble the rear end.
- Ron&Gill
- Been thanked: 21 times
The mini-T tunnel top and bottom also started to seperate. Good old Abie laid a neat bead for me...
Nice seeing you again Tom.
Next time lunch is on me.
- Tom Bishop
- Single Port
None of my parts came through this week so its a weekend of lazing.
Good to catch up with you Chris.
