So having a thought that the profile is somewhat similar to a hydrolic piston rubber as those are also flared on the outer lips
Made it my mission to find something better to use than the current solution
By lowlightwarwick at 2012-08-30
Od 50 and Id 40 with a 5-7 flare - has to be something out there less than 50 zar !!!!
The mechanical mission continues
Stripping down the kings and links
Need to make a puller to get the king pin out
Then will get out all the bushes for samples for my mate that he can get a replcement "kit" going
Generally the settup looks good -was still grease in all the moving parts
Link pin needle bearings seem good and snug in the bushes - a little bit of play on the lower king pin bush
Will have to wait for the puller to see whats happening in there
Got the brake master and slaves back yesterday - just one front slave needs attention as the bleed nipple does not engage properly so going to drill it out to 6mm and then put an 8 mm tap and nipple in
Got a lession from the GS Master yesterday on the cleaning of the release bearing - so that is also on the cards
Thankyou again Grand Master
Sand blaster will also be put to work on the backing plates so I can finish them off and fill that brain fade gap
Allot planned here will hope to get a few hours in this weekend
One day I hope to swop places with Sean and get just 1 full 12 hr stint
