Page 9 of 15
Re: Beetlefanatic`s Cabrio By Bugger
Posted: Sun Mar 22, 2009 10:49 am
by bugspray
Oh and an iPod would be wickid. But no radio functionality.... I think. And if yov do that, your going to need a pre amp or equalizer. The amp alone wouldnt b able to tune the right frequencies. Instead of 6*9z. Go with co axials in the rear under the seat, of if the front seats are done yet, put the speakers in the back rest. Herzt, JL audio, rockford, xtc audio are schweet. Check out metro audio or something like that. In the speed and sound mag.
Posted: Sun Mar 22, 2009 11:18 am
by 1972
rockford fosgate :) :hangloose:
Posted: Sun Mar 22, 2009 11:26 am
by beetlefanatic
1972 wrote:rockford fosgate :) :hangloose:
I love Rockford, but the prices! I think there's only one place importing them and accredited to install them.
Posted: Sun Mar 22, 2009 11:28 am
by Chris
Buy Lightning Audio,it's a subsiduary of RF.It's basically RF in a different package.It's what I use and half the price,same quality.
Posted: Sun Mar 22, 2009 12:13 pm
by bugspray
Yup lightning kicks ass! RF in sheeps clothing. Go read up the ice thread, theres something about a droptop, and sound insulation, you may need that.
Posted: Sun Mar 22, 2009 11:47 pm
by Bugger
This was a :bn: load of work to get this front end sorted with all the Urethane bits
You will see I maneged to get urethane cups even for the Tierods so had to strip the std cups off
Then the urethane cups would not fit properly then the Thick antiroll barr, had to modify the urethane mounts there
also aswell
But it is looking good
Just need a few small items to finish the front end off ready for fitting
Posted: Sun Mar 22, 2009 11:53 pm
by 1972
wow that looks great ,nice work
Posted: Mon Mar 23, 2009 12:03 am
wow
Posted: Mon Mar 23, 2009 12:22 am
by ZeroAxe
vader wrote:Well you take a set of disks choose a drill bit, take it over to the drill press, center punch your pattern onto them, drill away and hay presto you have crossdrilled disks...
I am sure you can go about it this way, but do you REALY want unbalanced discs??? With your Baja rusting aprt already, do you want it to SHAKE apart as well???? :shock:
Posted: Mon Mar 23, 2009 5:37 pm
by Matt
for quality and affordabillity....6 inch starsound splits-front and back
4ch audiobank amp(ive had my amp for like 3 years and i hammer it, and its proved itself)
personally, i would say thats the best quality for rand spent. dont waste your time with 6x9's, they might save space and easy to install....
...but u'll neva get the sound quallity that you would from a split system. and the 6 inch is enough bass. if u go starsound with the amp, even better.
compatible components always work better. and u'll have a kickass install if it all one brand.
im sure plenty ppl will disagree.... just my opinion
Posted: Mon Mar 23, 2009 5:40 pm
by Matt
by the way...is that anti roll bar standard? i see u talking bout the "thick anti roll bar"
looks very awesome....i feel a bit of jealousy coming over me.
congrats
Posted: Mon Mar 23, 2009 5:41 pm
Matt wrote:and the 6 inch is enough bass.
hmmmm.... they have good mid-bass if in a decent tight small enclosure, but most 6" drivers cant even produce the frequencies that is usually referred to as bass. They fade out around the 120Hz region.
Food for thought.
Posted: Mon Mar 23, 2009 5:56 pm
by Pine
- 6 inch starsound splits-front and back - R 7K, more or less
- 4ch audiobank amp - R 4K, more or less
- driving down Margate beachfront blasting Loslappie on repeat at deafening decibels - PRICELESS!!! :twisted:
Posted: Mon Mar 23, 2009 6:07 pm
by Bugger
Matt wrote:by the way...is that anti roll bar standard? i see u talking bout the "thick anti roll bar"
congrats
It is a after market thicker one much stiffer than std
Posted: Mon Mar 23, 2009 6:12 pm
by 1972
bugger have you got more pics of the front beam???
