- 62vwbeetle
- Oil Seal
- What model do you have?: 62,66,69
- Has thanked: 6 times
- Been thanked: 12 times
Stepped door strikers on Karmann one is completely trashed the other has been fixed before with a half circle rubber grommet. So it is also +{*{ed. Cleaned and polished housings. @calooker I need 2 repair kits please
- 62vwbeetle
- Oil Seal
So I was in cleaning mode so grabbed my really old and dirty yellow fog lamp stripped and cleaned sit up. Polished the dull chrome up and re assembled. This is for the old grey goat.
- Dazz
- Has thanked: 2 times
- Been thanked: 4 times
On Saturday was me fagher's birthday so we took the Kombie as we had a massive family picnic at the pretoria botanical gardens.
Everything running shaap. Then on Sunday while taking the kids back to their Moms.
All of a sudden a massive pop and it sounds like a tractor. So i stop on the Zambesi shoulder.
I have a look and the zhorst is fine. I notice one sparkplug is out. It was laying ontop the head.
No sparkplug spanner. I had a longnose and a phillips screwdriver. My Wife foumd a piece of wire next to the road and i managed to hook the plug using a hook i fashioned with the wire. So the kids Mom came with a sparkplug spanner and i managed to get the sparkplug back in again. 5 blocks from home it popped out again so we had to limp home. I hope the plugs thread in the head isnt stripped or anything.
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
1975 Kombie
1979 Kombie
W203 C320 CDI
- hitlers revenge
- Been thanked: 36 times
Sorry to bring bad news, but thats a helicoil you need.
partially mocked up a stroker motor
- Retrobug
- Has thanked: 15 times
- Been thanked: 32 times
Got into my bakkie reversed out of the garage, saw it was a beautiful sunny SA day, drove straight back into the garage.
Piled my boys into the Beetle and went on the school/ work run in style!
Nothing beats cruising with the windows down in a Beetle!
Mars67
- What model do you have?: Porsce Spyder
- Has thanked: 3 times
- Been thanked: 7 times
The adjustable front suspension is done. Now I am in two minds as to having it powder coated or painting it with 2K myself. If I paint it myself I can be done by the weekend but it is unlikely that the powder coating will be done. I need to paint some other parts of the front suspension as well and modify a brace that attaches to the front suspension and supports the long nose of the Spyder to clear the adjuster that was welded in.
- Gerlach
- What model do you have?: 1976 Type 1 beetle
- Has thanked: 9 times
GO with power coat. last longer and really strong and wont chip of. Rather wait that time longer and do it right. And electro plate the arms, then they wont rust. this is how mine looks.Mars67 wrote:The adjustable front suspension is done. Now I am in two minds as to having it powder coated or painting it with 2K myself. If I paint it myself I can be done by the weekend but it is unlikely that the powder coating will be done. I need to paint some other parts of the front suspension as well and modify a brace that attaches to the front suspension and supports the long nose of the Spyder to clear the adjuster that was welded in.
Mars67
Wow that looks awesome. Good advice thanks. Not intending to hijack the thread but did have the entire swing arm plated, including the shafts going into the tubes?
- Gerlach
Jip, the entire swing arm and shaft have been plated. just add a lot of grease in side the shaft where the spring plates are in. after assembling , take the grease gun and add more in by the grease nipple.Mars67 wrote:Wow that looks awesome. Good advice thanks. Not intending to hijack the thread but did have the entire swing arm plated, including the shafts going into the tubes?
- dixtoy
- Has thanked: 60 times
- Been thanked: 37 times
Helped a friend fit a recon box on his CAT baja
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
1971 Westy (Gypsy)
- Dutch_Diver
Fitted a new present from the US of A
Mars67
Collected my front suspension from powder coating today. Had it done a "gloss black" only to find that it had what looked almost like a metallic finish but on closer inspection turned out to be white spots/dust baked into the gloss black. Turns out they were doing gloss black in the one oven and white in the next and did not close the doors properly. It's overspray white which is nicely baked into the gloss black! I thought the owner was going to beat up someone but anyway its back to sandblasting and coating again. I said I need the parts by the weekend and the owner agreed so someone is going to be doing a little over-time.
Mars67
Collected the front suspension from powder coating again today. Looks good now and also got the grub srews and lock nuts from electroplating. So the front suspension is going on tomorrow.
