new guy questions
jeff115
What model do you have?: ?
Re: new guy questions
Post by jeff115 »
eben wrote:320hp Subaru engine in a bug equates to 0-60 in 3 seconds, 1/4 mile in 11.7seconds.
That is faster than a McLaren F1, Porsche GT3 and Ferrari 355 :wink:
:hangloose: exactly what im looking for how many doctors kids in there $250k cars are expecting an old beetle to be faster than theres i got 5 or so more you cant do it replies on another forum so im really getting motivated to do this thanks again for the help guys
twin turbo 94 12 valve
jeff115
Post by jeff115 »
Tony Z wrote:an engine that size will mean nothing more than bad handling
Plus it will weigh more than the car iself
oh i didnt mean use the motor just was wondering if the transmission could be bolted in to a bug or easily adapted then have the little subie bolted on to that o thought maybe if i used a transmission that was made for a 600hp v8 it would be overkill enough for a daily driver
Been thanked: 487 times
short of building your own car on a tube chassis and simply putting a beetle body onto it, the only gearbox that fits inside a bug is the bug box.
You;ll have to get a fully beefed up gbox from someone like Rancho.
One thing you might want to consider.... with the power you will be using, you can use a stock weight flywheel instead of lightening it. Yes, this will reduce your acceleration time a ball hair, but the heavier flywheel will want to slip the clutch slightly linger during heavy engagement which will extend the life of your gearbox dramtaically - assuming that its power that will break the gbox, not wheel hop or driver abuse.
jeff115
Post by jeff115 »
ok i gues ill stick with a normal tranny and if some thing does break it will probly be from driver abuse i hate to say but thats probly what it will be gues ill just have to fix what ever breaks
a normal tranny, as is stock and unmodified will break in seconds under that power. 150hp is about the limit for a stock box and even then, it wont last long.
jeff115
Post by jeff115 »
dude k an after market volkswagen transmission i know stock parts wont work
:) PM a member called bugger on here. You will see his banner at the top of the page too. He builds VW transmissions for a living, beefed up ones as well and might give you some insight about your requirements.
His site is http://www.buggertransmissions.co.za
dubster
Post by dubster »
Jeff i think you have to get the bura motor in there first get everything sorted on the car handelingwise,cause even a stock turbo bura motor will pull very and i mean very hard in a bug...sort all the glitches that occur with the stock motor and then to extract more power from that motor cant be hard ie.bigger turbo,bigger intercooler ect..There is a speedster on here that has one in fairly stock and he sais he killed a m5 the other day... Look for it in projects section you cpuld get some tips there...
1974 1300tp type 1
kart kraft 1717cc buggy
jeff115
Post by jeff115 »
dubster wrote:Jeff i think you have to get the bura motor in there first get everything sorted on the car handelingwise,cause even a stock turbo bura motor will pull very and i mean very hard in a bug...sort all the glitches that occur with the stock motor and then to extract more power from that motor cant be hard ie.bigger turbo,bigger intercooler ect..There is a speedster on here that has one in fairly stock and he sais he killed a m5 the other day... Look for it in projects section you cpuld get some tips there...
thats kinda what i had planned put every thing to gether have all the drive train ready to handle a bunch of power drive it for a little bit change what needs to be changed then start adding more go
Been thanked: 21 times
Post by Ron&Gill »
Subaru conversion is very common. Google it. There are kits available.
Just remember in the states he will probably buy a beetle with IRS suspension then there are alot of different things to get to make this setup as close to reliable as possible 930 Porsche cv vlanges + cv joints and Chrome molly shafts after market everything then just go out and buy a mendeola box that is what the Guys use running the Corvett motors a mendeola is I could be wrong $15000 :shock: but the right thing to get
