Overhaulin Samba
Re: Overhaulin Samba
That Eben, means F-all to me, you could have written it in Slovakian and it would have meant just as much
- Site Admin
- Been thanked: 54 times
Ok here goes. The file you downloaded is called a .torrent file. It is a file that keeps track of where you can download the required data from but you need to open it with software that will enable you to connect to the data sources to download the actual video file.
This is the simplest client http://www.utorrent.com
Download and install and open the 13K file afterwards with this. Your download should then start
Thanks Eben, I'll try later...
Its downloading... thanks Eben
