The place to ask your "Stupid Questions" thread!!
- ChrisG
Re: The place to ask your "Stupid Questions" thread!!
When people talk about lowering suspension, is 30mm a big or small drop?
I want to drop the suspension a tiny bit to fit my car in the garage but I don't want to look of a lowered bus
http://thegreatadventurer.com
Twitter: @TGadventure
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Ummm how DO i get access huh vader? hahahaha. People never learn. Haha. Oh and 30mm isnt a major drop, its what? 3cm.. I had a fiesta with a 60/40 drop. 60mm front, and 40mm rear. That was low, kinda too low. But a 30mm is safe. You just lowering it by 30mm from the exsisting height. Go measure the tyre wall to fender gap.then minus 30mm. I say do it.
ZeroAxe
- Drive Train
Just let the air out before you drive into the garage and give the tyres a "fill up" once outside the garage!!! Simple, huh? Sometimes the easy answers are right in front of us!ChrisG wrote:When people talk about lowering suspension, is 30mm a big or small drop?
VW Enthusiast
- ChrisG
I'm thinking of actually getting a really heavy box of bricks or somethings, that is the other option
- bugspray
- Floorpan
time consuming,wouldnt you say?
- bugspray
- Floorpan
Yeah thats what i was gonna say... Add weight, sub boxes, or a bag of cement..
Erased the email a while ago Vader, so cant post them...vader wrote:too lazy to post the picks sorry Blitz...![]()
Mybe TonyZ will do it..
This is something he sent me and I got to wondering about BFSC as this ships engines efficiency exceeds 50% thermal efficiency @ max economy....
unfortunately this quote isnt correct... it achieves the high effiency yes, but not all of it is converted into motion. It should refer to the power which is produced from the fuel, not the power made for propulsion.vader wrote: Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
Engines like this occasionally have an extra "turbo" which is actually a turbine driven off the exhaust gas. With Turbos now becoming so much more efficient, there is often excess exhaust gas which can be used to make power, hense the turbine.
The exhaust gasses in the uptake exhausts also go thru "economisers" and / or exhaust gas boilers which is basically a bank of tubes filled with water. This water gets heated and then turns to steam. This steam is then used to heat the fuel and assist purifying the fuel, and might sometimes also be attached to a steam turbine which produces electricity.
All these uses would normally require a generator to run and provide the power, but instead, the exhaust gas in this case is being used to provide this power and extra power from the turbines (that is until the exhaust gas turbine stops working because the shipping company is too cheap to send people on courses on how to maintain them).
- bugspray
- Floorpan
Why would you want to change it?
- bugspray
- Floorpan
To Bring it up to date, i dont know, maybe have better clearer windscreen, more updated car, bring the old bug into the new centuary
- Dutch_Diver
WHY THE F2UK DID YOU START THIS THREAD VADER!
- vader
- Has thanked: 9 times
For questions like this bud....Dutch_Diver wrote:WHY THE F2UK DID YOU START THIS THREAD VADER!
- Dutch_Diver
Why do you get hang-overs after a heavy night of drinking?
- bugspray
- Floorpan
Mainly dehydration, and toxicity of the blood.
- ChrisG
What is meant by SO55 etc, is it like a camper model or something? Do all busses have an "SO" number?
