I was referring to High Pressure fuel hoses like Rui said. Also decent clamps as well.Tony Z wrote:As for the fuel lines....
if you are referring to HP lines as copper or stailess lines.... you need to put in at least one flexible piece of hose to take up vibration and the resulting stresses.
I know, its been done before without the flex hose, but it wasnt right then and it still isnt right now. I have seen a copper fuel pipe (on a ship) crack and leak because of the vibration which caused it to work harden and become brittle.
I know that there are several problems that I have to overcome with diameter of the air filters bases and the carbs calooker and fitting the manifolds from an SP will simplify things, however then I'd have to change the linkage as well. Man nothing in world is easy....
