So...what are you doing on your car for 2012?
Klaus
Post by Klaus »
calooker wrote:
Klaus wrote:
calooker wrote:Get a stroker motor for my SC together 2110cc, build the 2332cc for the Spyder, get the Notch on the road again, IF the shoulder holds out :shock:
So doodle is not going to dabble around too much any more with the stroked motor !
DOODLE is that who he is ??? :lol: will get a kick in the but soon, well.... hopefully.
Yep, named doodle after the first owner. Used to doodle with a pen and pencil all over it as well as do some quotes and calcs !!!
Enjoy bud, if you need a hand we should organize a spanner party
Klaus
Post by Klaus »
JonnoDub wrote:Well I will be starting on my beetle profect in February when I return from Incredible India , the plan is to sell and to get myself one of those Uber cool Bay window kombis before they get too scarce!
Yep seems to be getting harder to find a decent low light bay now a days.....
Think we should stock up
sean
Has thanked: 63 times
Been thanked: 227 times
Re: So...what are you doing on your car for 2012?
Post by sean »
These are the two that are on my list this year.
I have been procrastinating over this for quite some time but decided I really want to get my 59 split on the road. It will just make such a story considering its rescue a year ago now. First thing is to get suspension to get it rolling that I can get it into the garage to get started.
This was what I was initially keen for was my old series 2 Land Rover, it runs well but needs attention to the door frames which are rusted at the bottom and some small rust on the firewall plus all the rattles and leaky doors etc. etc. I want to do a complete strip down and rebuild that Tonia and myself can comfortably hit the road with it and do a lekker rough 4x4 trip but decided it will wait till I can get the 59 rolling.
brianj
Post by brianj »
tropical roof on that landy?
My plan is to get my dc closer to stock by going back to the original wheels and sorting the bumpers. Just need new hubcap clips rivetted on - anyone know who does this?
The fasty may get the rostys for a while to wear down the tyres... no plans for the fasty after the new engine last year.
sdudum
Has thanked: 2 times
Post by sdudum »
This year, I plan to finish my project and get het on the road legal...
- Buy new alternator - current one is giving me the warning light
- Install my burgundy soft top roof ;-)
- Find a heater and demister for the car
- Sort out the engine once and for all, she does not seem too happy, need a mechanic
- Sort out the car's stance - need her level, the back is a bit high
- Sort out the suspension - wobbly as hell, thanx for the advice I got from acvwsa forums
- Build a center console
- Fit radio
- Fit alarm
- Fit Tracker
- Replace current tyres / rims with 15"s
- Figure out if I can get the fenders/ wheel arches expanded $$$$$
Aaaaaahhhhhhhh, I am so far from finishing this thing...
[quote="sean"]These are the two that are on my list this year.
Here is a late Christmas present from Jean and myself - enough to get the '59 rolling at least :hangloose:
- I believe that you WILL actually get this '59 on the road - one mammoth project Sean - good luck - we'll all be watchin and waitin :lol:
sean
Post by sean »
Thanks once again Paul and Jean. This is most kind of you! :drunks: :hangloose:
This is a real head start to my 59 project. I can't wait to get it on the road. :D
I am going to be there ASAP to collect that van. I have twisted my old man's arm to make some space at his factory to store one of my other cars, so I have a space waiting for it in the garage! Ready to start ASAP.
Klaus
Post by Klaus »
Looking at lowering the bay and the SC. SC was previously lowered and easier to lower it again to get it tracking right than sort all the issues out with the rear suspension. The bay needs to be lower, not pavement sucking, but lower to get it in the garage with the rack on and leaving the brick work and paint in place. Will just make it more user friendly for all.
The SC might get some tilt and bows if I get the time as well.
The bug is going off to be assessed for new floor pans on both sides and a refresh of the paint.
Other than that not much..... Unless we find another bus ;)
MELLO YELLOW
Post by MELLO YELLOW »
My plans are to sort out my westy (licsencing :shock: ) so that we can start doing the camping thing again
And then also start my buggy project, cant decide which one to build :? .
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
MELLO YELLOW wrote:My plans are to sort out my westy (licsencing :shock: ) so that we can start doing the camping thing again
HAVE YOU GOT MORE THAN ONE?
post some pics or tell what type of bodies youve got
MELLO YELLOW
I have two buggy bodies :twisted:
One is a Kestrel which is in better condition but I do not like it becuase of the front window which is, A: too high and B: i do not like the triangular window sides that close you in ( I have all the glass for the windows
The other one is similar the the yellow one that is in the broshure that Pine found at Piston ring and posted, but the body is in need of some TLC
buggyfan
Long Block
Post by buggyfan »
you can always cut the triangle windows out
Has thanked: 235 times
...or install a smaller windscreen!
Matching ports, lapping valves, repairing some rust, fitting a new gasket set & electric fuel pump & attend the MWM 2012 in July in Zvolen.
MELLO YELLOW
But then you lose the ridigity of the window frame, I dont have the roof
