This is one of the first pictures that went into my collection of 'reference pics' for my Speedster build.
The rear interior of the replica does not look this way however.
They made it the way it is because it makes the body easier to mould. I did like the practicality of having a lockable storage area but it just isn't original and when I set out building this car my goal was to make the car look as close as I could to an original 356.
This modification began in August 2009 as a pretty straight forward process. I called up Eugene (Ex KCC owner) and asked him if there was anything structural about he rear 'back rest' panel. Without me even having to explain what I was about to do he just said "I know what you are planning to do, it's something I always wanted to do to the car... go for it!" So with his blessing I began. I planned to cut out the panels and expose the firewall which would make the interior 'good enough' once carpeted. But the build took a nasty turn after I had removed the 'back rest' panels.
Once the panels were removed they left behind an odd looking overlap in the floor which would have shown through the carpet.
After much deliberating I phoned Eugene again and asked him how the panel was secured and if there was any material under the thick white panel. He said that it was just Pratley puttied against the black inner tub which formed the firewall and rear floor and that if I just I just pulled on it hard enough it would break loose. Right... so I cut shallow grooves all round the panel and then began pulling it up with all I had. I could feel my weedy back muscles just about pulling out of my back but continued because I could hear the putty cracking. It became easier to lift and eventually with a load *CRACK* the panel came out and I lifted it high above my head with the recoil and almost fell out of the car. I then looked back at the car to see how it looked without the panel and I saw this:
I felt pretty sick when I saw the gearbox and thought about all the work i would have to do to reconstruct the floor.
I decided to fabricate a plastic floor which a could then mould in fiberglass.
This tuned out okay but I was not happy with the very rectilinear look.
I was stumped so I pretty much left the car like that while I looked for an alternative. A few months later I saw the progress of Impi's Coupe build thread and explained my predicament to him. A few months later I took a drive out to his place to collect a beautiful new rear interior and, as a total bonus ... a deck lid inside skin!
The weekend after collecting the new parts I went round to try them out on the car (It is 'sleeping inside my in laws spare garage a few blocks from my house) Things are a bit cramped there and I dare not fire up an angle grinder for fear of receiving a barrage of strongly worded letters. I had a quick look and then locked the car away again.
This past weekend I decided to bring the car to my place for the weekend so I could get stuck in. I have actually been trying to get going for the past few weeks but have had no helpers to assist me in towing the car. Yup, that's right, it doesn't run any more. What is worse though is that when I parked it two years ago I inadvertently left the handbrake up and the shoes have welded themselves to the drums so the car can't even be pushed.
My wife eventually succumbed to my begging and agreed to drive the tow car. I managed to free up the brakes enough to get the car out of the driveway and hooked up to the Passat. While being towed along I also noticed that the tires are now 'square' from being parked in one place for so long... bouncy bouncy. Anyway, a friend arrived to help me push the car into my garage and the work began. I eventually decided to cut off the two side panels you can see in the picture because there is just no way to incorporate these features into the existing body without extensive cutting and gluing and even then I am not sure how strong the body will be afterwards. Here is a picture taken about half way through.
I spent the rest of the weekend cutting little by little off each side and test fitting until it fitted nicely. I also decided to remove about 50-60mm from the top of this sub-frame beam:
Once that is cut down the new panel will fit in perfectly!
