Operation Sweet Pea-take 3
Warwick-Lowlight
Re: Operation Sweet Pea-take 3
Post by Warwick-Lowlight »
Warwick-Lowlight
Warwick-Lowlight
Well my Danny vanished last week - must have had a big Valentines
Monday here we go again
Skin on some polyurathane sealant between the arches and some weight on the roof Gand F clamps to keep the bugger down and the welding/ brazing can begin
This was possibly the long way round but we felt that the finish on the hole that was the sunroof would not be as "easy" as this way
There was also the abvious rott on the corners under the skin that we only saw once the old roof was off
When all is done should have a good new roof with all the corners repaired for another 40 years or so
Here some pics
Last edited by Warwick-Lowlight on Mon Feb 20, 2012 12:59 pm, edited 1 time in total.
Warwick-Lowlight
One pic did not come out so cool with the refelction from the metal but it shows the bath brazing on the holes that were made to remove the welds on the old skin
Warwick-Lowlight
And the beat goes on
Right side filled and ready for primer
Nose sealed off also ready for primer
Rooof is on sanding down to get the lines roight fill sides and primer
I was looking at all the boxes of goodies and have decided this body work is the easy part
Putting all the bits back where they should be and finishing off is going to be a test for me as I will have to keep reminding myself to take it slow
Anyway progress is happening
Well done on the roof Warwick :hangloose:
Warwick-Lowlight
Well slowly getting there got some green on and finishing the sills and roof -sanding
will hopefully get the cream on by Friday
Then the big game begins to put it all back together again
:hangloose: :hangloose:
MarshallGTi
Camshaft
Has thanked: 7 times
Post by MarshallGTi »
looking good man.....
Ryan Marshall
3250
Warwick-Lowlight
I am loving this
I cannot wait to get this green thing back on the road
:hangloose: :flash: :hangloose:
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Looking neat Warwick :hangloose:
I still can't believe how quick you managed to do this. Good going!
We must make a turn some time to check it out :?:
Warwick-Lowlight
Thanks Sean
Dude keep the 12 may open please
Have a School fundraiser and think you are ur bus will be needed up here with a beeg braai after the event :hangloose:
Warwick-Lowlight
Was looking thru some pics and found this one
Just remebering why I started this repair -Seems it has taken a bit longer than expected but we are nearly there
Seems like a good before pik in the setting sun
Will have to go back and get an after one
By lowlightwarwick at 2012-04-17
Update at the moment
just waiting for Sam seems like the oke was a bit sick last week
Then lining in - windows in and off we go
Warwick-Lowlight
Well as this is being typed Sam is busy with the roof lining - my "new bows work so good I have replaced the whole lot - that was sams suggestion and he has seen a few roof repairs -they realy push the lining up nicely
So the Applewood day is fast opproaching and the main display is still in a few pieces
Nothing like havin a deadline
Here the list of things to do
new rubbers for all the windows and replace windows
Clean up jaloiuse windows and install
rock and roll bed mechanism comming tommorow
Make box and fit the chair - cut foam and cover
Starighten front bumper mounts and secure bumper with new foot rubbers
Attatch Volkswagen script - Done
Fit new indicator lenses and covers - Done
New sliding door rubbers - done
Hang the door
Front door rubbers
Put back all the panels
sort out the starage area
Holding thumbs on all of this
Cant have the organiser of the day comming in a half done car
Will post some pics after lining is in
Warwick-Lowlight
Well job done on the roof - anyone who needs a roof sorted here in the cape Sam is the man contact 0734429516- any of your car needs on trim I'm sure he will sort you out - Rate very competative!!
A few pics of where we are at
The man at work
By lowlightwarwick at 2012-04-24
The finished product
Hey indikaytors :D
Best in the box - the real scrpting
Next job busy with - rubbers on the foot stands and level the front bumper
Inside pannels back on
Base for the rock set
So watch this space
Warwick-Lowlight
Seems I forgot to post the final pics
What with the last of the apple season and then the Splitt seems to have skipped me mind
Well here they are
The forum loved pictours
