My speedster is not sitting well...help
- MINCE
- Has thanked: 4 times
Re: My speedster is not sitting well...help
Dude. I am certain that all of us are not here to rip you a 'new one' over your wheels choice.
By the flare on your wheel arches, I can see it was what you were intending.
Is there room for installing shortened swingarms in the back?
- sdudum
- What model do you have?: 356; Beetle
- Has thanked: 2 times
- Been thanked: 5 times
So, bearing in mind that I bought the car with the arches and the wheels. So i took over an unfinished project. Not that I am running away from my responsibility in the build, I liked it when I bought it. The wheels are destined to go anyways, I am just concerned with finding a permanent solution to the stance issue, whether it be on 17s or 15s...The discussion about the 15" wheels is taken on-board,no argument there.
The engine and gearbox lift...what does that take, cost wise ?
- Has thanked: 36 times
- Been thanked: 50 times
I've been quoted R2500 to do the lift and that includes two new custom engine mounts. The price includes the rear frame rail plate that lifts the mounting points of the gearbox (in my case, 2 inches). a new cross member for the front of the gearbox as well as having the shifter rod moved to the top of the tunnel for that vintage racer look. Plus also moving the handbrake lever to under the dash. So not a bad price.
I seriously wish you luck with your ride, drive it like it is for a while and enjoy it while making plans along the way as to what you want to do. The more quality speedsters on the road............the better. SO if you need any advice, ask the crowd in here.
- Been thanked: 98 times
I think the reason it's sitting so high is due to the coil overs, you have 2 options to get the back down, dump the coil overs and fit stock shocks, or cut 2 coils off the spring, done this before, sure helped. Hope you come right.
- sdudum
Hijacking my own thread....those that own replicar speedsters...where dis you have it insured ? How much roughly and process ?flatfourfan wrote:I've been quoted R2500 to do the lift and that includes two new custom engine mounts. The price includes the rear frame rail plate that lifts the mounting points of the gearbox (in my case, 2 inches). a new cross member for the front of the gearbox as well as having the shifter rod moved to the top of the tunnel for that vintage racer look. Plus also moving the handbrake lever to under the dash. So not a bad price.
- sdudum
hhhmmm, I like this idea, just one silly question....will I not get myself into a situation where the shock is bottoming out if I cut the coils....?calooker wrote:I think the reason it's sitting so high is due to the coil overs, you have 2 options to get the back down, dump the coil overs and fit stock shocks, or cut 2 coils off the spring, done this before, sure helped. Hope you come right.
- sdudum
FFF, what size rims are you running and what are those called ? Where would I get them if I wanted to buy that type...flatfourfan wrote:Hmmm, common issue with our local speedsters as we don't have IRS. You can clock down the rear suspension and face a bit of negative camber or do it the proper way..........gearbox lift, which will lift the engine up and allow you to get the arse way down. I have the same issue on my speedster, I want the back down about another 50mm or 2 inches.
Plus I say this in a really nice way, those rims need to come off.
Big wheels are do-able, but it's also going to have that hunched look about it. And honestly.........it stil looks crap.
Best stance by a long shot IMHO.
Never. The bump stops are there to prevent that from happening.sdudum wrote:hhhmmm, I like this idea, just one silly question....will I not get myself into a situation where the shock is bottoming out if I cut the coils....?calooker wrote:I think the reason it's sitting so high is due to the coil overs, you have 2 options to get the back down, dump the coil overs and fit stock shocks, or cut 2 coils off the spring, done this before, sure helped. Hope you come right.
The rims on my car are mangles wheels. Pretty much an exact copy of the 356 wheels. Damn hard to find a set nowadays though. They stopped making them in the 90's, but I can't see why replicars in jhb wouldn't still sell them as they advertise them.
marcel
i have 18"s on my speedster and it sits the way a porsche should sit
marcel
My speedster 9112.2 turbo twin spark motor, 280mm all round disks brakes, 18"s wheels.
Now if i could only get it to run.
all depends on the look that you're going for. In your case, the more modern look can work with big wheels. I still seriously rate your car marcel.......really fresh take on a speedster.
You need to really update your old thread boet....aint heard anything from you in ages.
- beetlepower
- Twin Port
- Has thanked: 3 times
- Been thanked: 28 times
Is the suspension issue not caused by the fact that the Speedster body is quite a bit lighter than the original Beetle body that the chassis was designed for?
0828378801
@reubenvn on twitter
0828378801
bingo..........that's also why stock beetle shocks on a speedster make the car feel like it's rock solid with no give. Total weight on a speedster is around 750kgs.beetlepower wrote:Is the suspension issue not caused by the fact that the Speedster body is quite a bit lighter than the original Beetle body that the chassis was designed for?
