Am I the only one Very slow loading etc from Site
- Site Admin
- Been thanked: 54 times
Re: Am I the only one Very slow loading etc from Site
You could run the speedtest here:
http://aircooledvwsa.co.za/speedtest/
If you speed is normal it might be your browser/PC/
If you speed is sub-normal it is your ISP/
I get 2,97Mbps
I get 2,97Mbps
- Has thanked: 19 times
louisvr45 wrote:I get 775kbps. Is your side still slow?
Thats like 7.75Mbps that should be FFFFFFFFFFF vinnig
- louisvr45
here is mine...
Looks like the site is slow some times
Your current bandwidth reading is:
354.10kbps
which means you can download at 44.26 KB/sec. from our servers
here is mine...
354.10kbps
- Site Admin
The site isn't slow, it would be your connection that has an inconsistent speed.louisvr45 wrote:Pierre
here is mine...
354.10kbps
If the site was slow I would see excessive load on the site.
- Site Admin
Some more interesting stats:
- louisvr45
eben quite intresting stuff.
I see the 443kbps is 59 Kb/s which is not bad on a 1mb line (I got 775kbps this moring.) IT all depents on the site, isp and network traffic.
Bugger what type of internet connection do you have? adsl(384 -4mb)/3g/hsdpa/dailup?
- louisvr45
I just tested my cell's hsdpa speed. got 1.5Mbps that is 199Kbps( 1mb file would take 5.14s to download)
Adsl isp defintely has an effect.
Eben where is ACVW server based? RSA or UK?
I got normal ADSL
So when I call Telkom to get my line sorted how can I check the line is properly right when the Techincian is here ?
- louisvr45
try pinging your isp.
eg start run cmd.
typy ping http://www.telkomsa.co.za or .net and press enter. you wil then see the.response time in milli sec. it shouldnt be more than 1k ms.
can other also comment here?
eg start run cmd.
