DIY Beetle Fuel injection conversion
4agedub
Been thanked: 13 times
Re: DIY Beetle Fuel injection conversion
Post by 4agedub »
I have not had much time during the last couple of weeks to do more development, but here's a couple of changes to the setup.
The end result is that no fuel pressure regulator is needed. :D
The system works as follows:
The original carburetor fuel pump is plumbed directly into the high pressure pump
The high pressure pump is connected directly to the fuel injector with a T-piece that is connected to a electronic fuel pressure sender unit. This data is then sent to the ecu and the ecu will then control the fuel pump speed in order to control the pressure. Also, I'm doing away with the distributor modification... I'm in the process of designing a bolt on crank wheel setup from which the ecu will read the RPM.
Basically in the kit you will get:
Spitronics ecu
1x e23 harness
1x e24 harness
1x map sensor
1x fuel pump with bracket
1x fuel pressure sensor
1x throttle body with injector and fuel connector
Fuel lines
1x Trigger wheel and sensor
So far the pricing will work out in the region of R6300.00 for the whole kit
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
livinvolkstyle
What model do you have?: 73" Beetle TP
Post by livinvolkstyle »
Hi. Any update on this kit so far?
One does not simply achieve Volkswaggerness
4agedub
Post by 4agedub »
I did not have enough interest in this setup, so did not pursue the idea much further.
andyrtmorgan
What model do you have?: '59 Ghia Coupe
Post by andyrtmorgan »
Bummer...
'59 Ghia
slak
Has thanked: 7 times
Been thanked: 32 times
Post by slak »
What throttle body were U using in these tests ?
U Only Live Once Right !!!
