Hmm ja, I dont want that to happen, Can someone post a pic of how the tinware looks in a bay, with a type 4 engineDawie wrote:Very nice.
Just remember to fit all the cooling tinware before you start driving. Otherwise you will cause permanent damage and soon suffer from dropped valve seats, collapsed piston skirts, etc.
Especially in a sealed compartment kombi application, it is ultra-ultra critical for adequate cooling to have all the cooling tinware in place, and your seal around engine should be in good condition. As in: you should not be able to see the ground below when looking into the engine compartment. It must be air-tight, and only draw cool air from outside via the vents.
Otherwise the used hot air will just be recirculated back into the cooling fan's intake. Getting hotter and hotter each time the air passes around.
This is especially critical with a type 4 engine, where the fan's intake is right there where the hot air exits.
Looking good so far.
Your question about the carb? The carbed version of the type 4 originally had twin 34pdsit2 and 34pdsit3 carbs, (one basically a mirror image of the other).
Jonnodubs latest addition or should I say "addiction"
- Oil Seal
- Has thanked: 13 times
- Been thanked: 9 times
Re: Jonnodubs latest addition or should I say "addiction"
- Oil Seal
The bay went to a wedding yesterday, everyone was ecstatic with the old girl!
- Oil Seal
Another photo from the Professionals
