The tub
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Re: The tub
Post by Cyndi Kritzinger »
HI TUB. (AS WE DON'T YET KNOW YOUR ACTUAL NAME)
CYNDI AND I WOULD BE GLAD TO HELP.
WE ARE SERIOUSLY BUSY THIS WEEKEND BUT WILL MAKE CONTACT WITH YOU DURING NEXT WEEK. WILL YOU SEND US A CONTACT NUMBER ON PM OR CALL ME ON
OH 8 2 4 FOUR 8 TWO 3 5 ONE.
WE ARE IN GLENWOOD.
WE'LL DEFINITELY TRY AND GET YOU SORTED OUT.
MARK & Cyndi
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Re: The tub
Post by acpaterson »
the_tub wrote:@ Tony Z
Please see below pic to check if I am feeling her coil in the right spot? Where my hand is I cannot touch it for longer then 3 seconds without burning too much
Howzit,
Based on what Tony said, and you're saying, it does however sound like there could be a overheating issue.. If you can't touch the Distributor for more than 3 seconds after a drive of about 1 Km, there's def something wrong.. Tony? Can you add more on to this? :?
Re: The tub
I'll be honest, I have never tried holding the dizzy while running to see how hot it gets. So no comment here...
but dont forget, its shaft gets splashed with 100deg oil, so it will likely be pretty warm
acpaterson
Re: The tub
But is this not the same as the Dipstick test? Are you not trying to measure how well the oil circuit is flowing\not flowing? If the Dizzy's very hot to the touch, then Id say so would the dipstick be possibly?
Re: The tub
acpaterson wrote:But is this not the same as the Dipstick test? Are you not trying to measure how well the oil circuit is flowing\not flowing? If the Dizzy's very hot to the touch, then Id say so would the dipstick be possibly?
Possibly. But dont forget, the dizzy spins, uses energy and has energy flowing through it. This all provides heat as a byproduct.
Tubs has an issue with the car cutting out after a short while. One of the causes might be a coil that is on its way out. That is what I am hoping he can check. If the coil gets flippen hot and to the point the juices start flowing out, then its dead. It should run warm, not hot.
Touching the dizzy wont tell you anything about the coil.
It is possible that the engine is so hot that it is boiling the fuel in the carb and thats why he cant drive anymore. But at that point, the engine smells hot and he hasnt mentioned this. Its pretty obvious when it is that hot.
the_tub
What model do you have?: vw kombi 1.6
Re: The tub
Post by the_tub »
@ Tony z thanks for the pic I haven't had a chance to run her to check the temp of the actual coil yet. He bolts on the fuel pump however where fairly loose already.
@acpaterson after reading your concern of her over heating I did a check over and under and this is what I found, please see below pic
the_tub
Re: The tub
Post by the_tub »
Big hole in the exhaust. Which I am sure was causing her to over heat.
I have now welded her up and going to get a few gaskets and spares before I reconnect and start her up.
If the problem persists I will then test the coil.
the_tub
Re: The tub
Post by the_tub »
Thank you all for your valuable input
acpaterson
Re: The tub
Good luck.. I kind of trust Tony 110%, but am just thinking "parallel" with him.. thats why I thought he might be onto something re: the oil temp. These are VERY robust motors, and can run even if there are some serious issues. I don't understand why yours is dying, I'm thinking mechanically that can't really happen, but possibly you might have an electrical failure, maybe your coil is breaking down when it gets warm, or a issue inside your Distributor. Hope you find the issue..
the_tub
Re: The tub
Post by the_tub »
@ Cyndi my name is Jarrod.
I would highly appreciate your visit, hopefully I can start her up before then. I am still going to need advice as to where I can get the following:
Windscreen wipers motors and control arms
Full set of front and back indicators
Side mirrors,
Key and ignition
Indicator switches
Full set of vw hub caps
Vw front emblem
My number is 0760334336
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Re: The tub
Post by bugspray »
Welcome and congratz Jarrod. cool looking bus you have there. Hope you come right with the heating issues. wish I still lived in ZN, but will have my aircooleds down soon enough for a bit. There is a gentleman in Hillcrest Waterfall area also that is awesome at aircooled repairs. I have added you to the Aircooled Whatsapp group.
hope you join and find answers and solutions, there is also a guy in here Hendriks, he has jusy about all you require for your bus.
