Page 2 of 4
Re: Lolette Spyder Restorarion
Posted: Sat Mar 14, 2015 10:08 pm
by vwpumagt
When i saw the ad,the 5 speed box made me curious as well. He said it had a 5 speed microbus/ caravelle box in when I phoned him. Is this possible?
Posted: Sun Mar 15, 2015 8:15 am
by Wentzel
I don't know if it can be done but the caravelle had cv joins didn't they? The box in the lolette is a swing axle so I cant see how it is a bus box. I will have a look when im atvthe car again to be sure and maybe bet a box number for reverence.
Posted: Thu Mar 19, 2015 8:45 am
by Wentzel
As far as I could find out the Spyder uses a Karman Ghia windscreen which i don't have yet. What are my options to get one or test fit before I have one made up for a lot of $$? Can someone help with measurement or will a Glass supplier be able to determine if it is the same? From what i heard the made up screens are around R2400.
Where can i attach safety belts in a car like this? will i need a mounting point on the body somewhere or will a lap belt be accepted? I was even thinking of a kind of Roll-bar similar to the Cobra's behind each seat and attach the safety belt to it? I'm concerned in case of a roll over without any roof or protection. What is the accepted way to do it in the Spyders without ruining the look?
Posted: Thu Mar 19, 2015 9:05 am
the car needs to conform to the regulations applicable when it was built. So if it is registered in an era that lap belts were all that was required, then that is all you need.
A roll hoop or cage wont be such a bad idea.
Posted: Thu Mar 19, 2015 9:46 am
by calooker
R2400 for a made up screen, I think not, R4500 was the starting price I was quoted over a year ago, and they need a sample to work from.
Posted: Fri Mar 20, 2015 8:06 am
by Wentzel
Ouch Rui I was hoping to get away with less that R4500!? Unfortunately I guess my options are limited to either that or a second hand screen. It is not something you can DIY or make another plan with.
Does anybody have or know of a second hand screen for a Ghia?
Posted: Fri Mar 20, 2015 3:20 pm
by Mars67
I am quite sure that I can help you getting a 2nd hand one. Alternatively Volkspares bring them in for about 3000.
Posted: Fri Mar 20, 2015 4:38 pm
by Wentzel
Thank you !
I would like to consider all options. I want to get the car roadworthy and regestered before doing the personal touches and body.
Posted: Fri Mar 20, 2015 7:24 pm
by John Alves
Take the one from Volksapares for R3000, I was quoted R 5 850.00 excluding delivery in September last year from Hein Steyn
0834486628 Classic Windscreens
Posted: Fri Mar 20, 2015 9:09 pm
by vwpumagt
As we have seen on overhaulin with the 356 rear screen , any screen with a similar curve can be cut to fit. I have spoken to a glass guy a few years back and he said that it can be done because they are laminated.Finding the right one is obviously the hard part and you would probably need a sample. Normal screens for golfs and toyotas are quite inexpensive(R500 - R700). If the R3k one(my first choice) doesn't pan it could be something to explore.
Posted: Fri Mar 20, 2015 9:19 pm
by Wentzel
Thank you for the info. I have even thought about plexiglass but not sure how to shape it and how safe it will be. I never thought about cutting a similar screen but definitely worth exploring that option.
Why are the screens so expensive? Supply and demand? Or extortion by the companies that knows customers have limited options?
Posted: Sat Mar 21, 2015 4:23 am
So expensive because of the glass, laminate and sometimes the difficult design of the window.
Prime example of this is my Mazda 6. The 2003 model (which I have) has a "normal" curved windscreen. A replacement cost me in the region of 4K in 2010. From 2004 they changed the shape of the hidden part to now bend from the curve to make a flat that follows the bonnet for a few cm. This one they told me was around 16K because its a PITA to make.
Maybe I am wrong, but thats what PG glass told me
Posted: Sat Mar 21, 2015 6:11 am
by Jdt1976
I did phone Krugersdorp Glassworks yesterday to check if they can find a KG screen. No luck there.
They can still get Bay screens for R900. Fitting excluded.
Posted: Sat Mar 21, 2015 7:08 am
by Wentzel
16K? Wow not cheap at all you could buy a car for that price.
Are you looking for a KG screen also Jdt1976?
Posted: Sat Mar 21, 2015 7:17 am
by Jdt1976
No, I don't have a KG.
