EL Puma project.
64 Notchback
- Has thanked: 78 times
- Been thanked: 37 times
Re: EL Puma project.
I'm interested in another one now. Would it be possible to fit a water cooled direct injection engine in a Puma? And would the radiators get enough air with those tiny little vents in the back?
How much space is there in the front boot and behind the seats?
- Mr_Cassidy
- What model do you have?: Puma GT
- Facebook: https://www.facebook.com/cassidy.naidoo
Why not go with Type 4 power like I did. I'm busy modding it to take an injection system off 2.1 wasserboxer motor. I've already done the electronic ignition system using a TP900 and a golf wiring loom with the distributor from the 2.1 it works like magic.
You get good reliable power and you keep the car true ACVW - It's pretty much just a bolt on conversion.
Check this out :
http://members.rennlist.com/pbanders/dj ... htm#setups.
It runs cool as the venting is sufficient as well.
I think the dual trumpets are a nice touch as well.
Just my 2c.
Regards,
Cass.
Check this out :
Just my 2c.
Regards,
Cass.
- VW-rules
- What model do you have?: 1961 Bus
- Has thanked: 10 times
Some development over the past two months.
"As is" delivered to the body shop.
The body was first removed from the chassis
Because the chassis was slightly "vrot"
Then the body filler to try and get all the lines back
With some blacking to bring out the lines properly.
The A post had to be cut out and replaced. The metal reinforcing inside had completely rusted, expanded and cracked the fiber glass
The inside was then prepped for the black paint.
Then the yellow on the outside.
Some speckling in the boot and engine compartment as well as some black detailing.
- VW-rules
The boot compartment before
Now the engine build begins. Hopefully reporting back soon.
WOW!!!!!!
- Has thanked: 425 times
- Been thanked: 543 times
Excellent work done on the body, what a day/night difference, you must be proud.
The pan looks like my 52 looked, I feel for you, but, the final result will be well worth it.
Keep it up
Keep it up
- Cyndi Kritzinger
- Facebook: yes
- Been thanked: 64 times
- Has thanked: 235 times
- Been thanked: 234 times
That really looks very good, one giant leap forward in your resto project, well done!
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
- VW-rules
This weekend I decided to buy the yellow bird a little friend.
I'm told by my wife that cars don't have feelings and that it didn't need a friend. She's just bias.
The friend is a very dark plum colour so I've called it Barney. Barney has a 2l aircooled bus motor and is scary fast, specially without brakes. Thankfully the hand brake works or Barney would be no more.
- jolas
Congrats Christian !
Thats also a nice trailer you have leaning against the wall there
Chardivw
- Oil Seal
- What model do you have?: 78 kombi 2000l
- Facebook: Snowater photography
- Has thanked: 12 times
- Been thanked: 15 times
Toys toys toys! Looking really good.Have you started assembling? Where did u find barney?
- VW-rules
Barney comes from Amalinda. I couldn't find a manual to do the re-assembly so I'm using Barney as a reference manual. Once I'm done Barney will be sold.
