HEADING INTO THE (ALMOST) FINAL STRETCH OF THE BUILD......
THE ENGINE.
DUE TO THE FACT THAT WE COULDN'T GET THE ENGINE TO FIRE WE DECIDED TO GIVE IT A ONCE OVER.
THIS PRETTY MUCH INCLUDED A FULL TOP END REBUILD.
I RE-DID THE HEADS INCLUDING VALVES, GUIDES, INSERTS ETC....
CARBURETTORS RE-BUILT AND BALANCED (BALANCING DONE BY A PROPER PORSCHE REPAIR GARAGE)
NEW GASKETS AND RUBBER SEALS HERE AND THERE
EXHAUST
COMPLETE CLUTCH
FUEL HOSE ETC.
PISTONS, RINGS,PUSHROD TUBES BLAH, BLAH BLAH........ YOU GET THE PICTURE.
AGAIN; JUST KEEP IN THE BACK OF YOUR MIND THAT THIS WAS APPARENTLY A RUNNING BUS THAT I COULD DRIVE HOME.
