Autovilla motor conversion
Re: Autovilla motor conversion
Hi best conversion is the Golf motor with Hidden Radiator under neath the Bus
We have done a lot of them including a few Autovillas
I had a bay window with golf motor and towed my Heavy Double cab Microbus on a car trailer with it
0826008663
All these have Golf conversations
Very reliable
P
leon@bbo
What model do you have?: 1981
Post by leon@bbo »
Hi guys
I have a '81 Autovilla with a Toyota 2.2 4Y motor. Water-cooled.
In December it suddenly started overheating. We already replaced the waterpump, thermostat and even the water pipes from the radiator in front to the back. Also fitted a fan ontop of the motor to try and keep the motor cooler. Nothing helped.
Any advice will be highly appreciated
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Your problem is you have a Toyota engine in a Volkswagen. It doesn't belong there. You will find if you throw out this contraption and install an original setup, your reliability will be restored.
leon@bbo
Post by leon@bbo »
Hear you! Unfortunately I bought it with this motor.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Have you bled the system correctly. You must take thst carb off and fit a 1600 golf carb the original not cheap one you wont beleive the difference smooth more power better fuel consumtion. Thats if you cant get a aircooled motor as Sean says. Make sure you have the 2.6 Caravel radiator 2 speed fan and cowling and a big header tank to hold more fluid.my 2c worth.
leon@bbo
Post by leon@bbo »
Thx Terry, will look into that
Has thanked: 423 times
Been thanked: 542 times
Are you running antifreeze ??
Have a look at your thermostat as It gets an air bubble under it and it will not open.
The old Toppies always drilled a 3mm hole in the thermostat disk to allow the air to pass but not to effect the workings of the thermostat.
All old conversions had this done to stop air trapping.
When doing racing all my engines had this and never had heating problems.
leon@bbo
Post by leon@bbo »
Thx Herman. Are you referring to water-cooled or air-cooled?
leon@bbo wrote: Mon Jan 29, 2018 8:18 pm Thx Herman. Are you referring to water-cooled or air-cooled?
No , water cooled, when you switch off a hot water cooled engine, it makes bubbles, and these sit behind the thermostat disk, when you start, the disk is cold with air behind it where the bellow is to sense the heat, so as the engine heats up, the air does not transfer the heat to the bellow and the engine overheats without the thermostat opening.
Now the little hole allows the air to pass through so this does not happen, and is so small it will not effect your normal cold start water flow.
leon@bbo
Post by leon@bbo »
Hi Herman. Thank you, it sounds like you have your fair share of experience! It makes perfect sense. I will definitely try it and will let you know the outcome.
Thanx again!
Leon
