Build projects by Vdubtech
V6 Capri
What model do you have?: 1972
Has thanked: 7 times
Been thanked: 29 times
Re: Build projects by Vdubtech
Post by V6 Capri »
Very cool project. Would be popular at Matric farewell dances... Or Masked ball as they will now be :lol:
Some mother's children with the body putty ne?!? :evil:
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1996 Escort 2L Zetec
2016 VW Touran 1.6TDi
1971 Baywindow project
V6 Capri
Post by V6 Capri »
Bugger wrote: Sun Apr 09, 2017 2:26 am Image
Black Speedster 911 motor and Extra long ratio Bugger Stg 1 box
Gold one Subaru turbo motor
Can't say I am a fan of brown cars in general. But this look amazing! :flash:
The Brown gold Speedster do look very nice indeed
Bugger wrote:I bought this limo about 2 years ago
It was owned by about 4 or more owners before and seem every one just put more polly on the previous
It also had a Rover V8 motor in
That I removed and installed a 2L Gold GTI motor
Sourced a Rack and pinion Power steering system with lots and lots of headaches I managed to get it to work
Now it is time to get Body work sorted
Started removing All paint
There are amazingly amounts of Body puty on this body
I have used 3 of the Special discs that Sean is using on his projects
Now busy with flapper sanding disc to remove paint and 10tonnes of body putty
It seems most is pop riveted together
So there is a much bigger task awaiting us once all paint is removed
1 Advantage is that it seems that who ever did the Chassis did not do a bad job there
But I will still be Adding a few additional supports
Also sourced a set of High jacker air shocks for additional rear supports
Wish us lock ImageImageImageImageImageImageImageImageImageImageImage
Ok I actually started a tread of it's own for the Limo
Under Discussions
Noah the limo Split bus
Go check it out
Some picsImageImageImageImageImageImageImage
