Clutch Judder
No More Landy
What model do you have?: Beetle 1971
Has thanked: 23 times
Been thanked: 6 times
Germany
Re: Clutch Judder
Post by No More Landy »
Modified spare socket to remove offending nut.
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
No More Landy
Germany
Re: Clutch Judder
So this is the tube that came out, slightly difficult to pull out the old cable in some spots little tight but not extreme, seemed like just gunk inside and a slight bit of damage on the outside.
Should I rather just go get another sleeve/bowden tube, or just clean out the inside of the old one and maybe add some more washers to get a bigger "kink".
Saw a few YouTube videos and it seemed they use 3 quite thick spacers on the bowden tube - is this same for all models ?
Edit - seems I mixed up a spare Handbrake cable with a clutch cable
1971 Beetle
2021 Polo tsi
No More Landy
Germany
Re: Clutch Judder
Seemed to have found cause. How would I have done this ?
Can I have the fingers replaced at Ferro Brake or just buy a complete kit ?ImageImage
1971 Beetle
2021 Polo tsi
Been thanked: 321 times
Re: Clutch Judder
Broken pressure plate diaphragm spring is just wear and tear. You can have it rebuilt, but I prefer to buy new while they're still available. Likewise the bowden tube.
No More Landy
Germany
Re: Clutch Judder
Tried Goldwagen and Ferrobrake with no luck - anyone else keep them in stock ?
1971 Beetle
2021 Polo tsi
Been thanked: 539 times
Re: Clutch Judder
Alert should carry them, or get it for you.
Midas carry some models, but not all.
No More Landy
Germany
Re: Clutch Judder
Midas have a LUK Clutch & Pressure plate (same as original) for R1,400
Alert parts have a powertorque for R780
Assume the Midas one is the one to go for ?
Edit: Granslam also have the Powertorque but price is a bit high.
1971 Beetle
2021 Polo tsi
Been thanked: 100 times
Re: Clutch Judder
There is also Goeie Hoop Onderdele in Brackenfell, and Masterparts.
No More Landy
Germany
Re: Clutch Judder
Oh FFS - the saga continues.
Now discovered the needle roller bearing in the flywheel bolt is toast also - must have been from the damaged pressure plate as it did not look like this when I did the engine work.
Do I buy the whole Bolt with bearing inside or can I just get the bearing itself ?
If anyone has a part/bearing number or supplier to hand to save me driving all the way to the VW guy I normally frequent. i.e Will a bearing supplier be OK ?
1971 Beetle
2021 Polo tsi
Re: Clutch Judder
It's called a Beetle flywheel gland nut and it's a single part. Not too hard to find.
No More Landy
Germany
Re: Clutch Judder
Found the needle bearing at Shelleys that goes in the nut. Was a bitch to get the old one out
1971 Beetle
2021 Polo tsi
No More Landy
Germany
Re: Clutch Judder
MacGyver job to tighten gland nut FT. with high lift jack stem tied to carport.
1971 Beetle
2021 Polo tsi
Re: Clutch Judder
Did you replace the bearing or the nut ??
No More Landy
Germany
Re: Clutch Judder
Bearing inside the nut yes
1971 Beetle
2021 Polo tsi
No More Landy
Germany
Re: Clutch Judder
Just torqued the pressure plate to flywheel bolts to 24 N.m - seems very small torque by feel.
What is the reason for such a small torque or is my Torque Wrench out of spec ?
1971 Beetle
2021 Polo tsi
