G-Tech Electronic igntion conversion for beetles and other points based distributors
Get your parts here
AlanH
Has thanked: 125 times
Been thanked: 86 times
Germany
Re: G-Tech Electronic igntion conversion for beetles and other points based distributors
Post by AlanH »
I think if you leave it in it is already there if you have to revert to points because the unit failed for some or other reason. Seems you would just need to refit the original cable from the dizzy to the coil.
Wanted parts:
Left sunvisor
Sink faucet
AlanH wrote: Tue Apr 12, 2022 7:53 am I think if you leave it in it is already there if you have to revert to points because the unit failed for some or other reason. Seems you would just need to refit the original cable from the dizzy to the coil.
that is my exact reasoning as to why I did it the first time.
To date, it hasnt been needed, but never say never.
