Page 2 of 3
Re: trouble shooting
Posted: Sun Aug 19, 2018 3:15 pm
by siraaj
hi Herman
belt not slipping,and i recently bought a new battery for the bug..so i'm puzzled..the slight wobble on the crank pulley was there but today it just sounded badly
Posted: Sun Aug 19, 2018 3:27 pm
by siraaj
ok..just checked my pulley and found that there is a slight play when i pull it back and forth...should it be liken that?
Posted: Mon Aug 20, 2018 7:13 pm
by siraaj
hi Rowan..any luck with your problem on your the bug ??
Siraaj
Posted: Mon Aug 20, 2018 7:22 pm
by siraaj
hi Herman
i had another look at my crank shaft pulley and found that my belt is in fact a bit loose,also that my crank pulley has a bit of play...i could actually move the pulley in and out a bit,therefore the noise....how do i adjust that play on the crank pulley?
I'd appreciate your advise
Siraaj
Posted: Tue Aug 21, 2018 7:23 am
by slak
Sounds like the flywheel might be loose
Posted: Tue Aug 21, 2018 9:25 am
by 73type2
First make sure that the pulley is properly tightened down, i.e., big bolt is torqued to the right tightness, before suspecting end float play.
Posted: Tue Aug 21, 2018 9:26 am
by 73type2
Also check if the woodruff key is not worn.
Posted: Tue Aug 21, 2018 11:20 am
by fourier
Is the crank and pulley moving, or is it only the pulley?
Posted: Tue Aug 21, 2018 12:39 pm
by Rowan
siraaj wrote: Mon Aug 20, 2018 7:13 pm
Siraaj
Hey
I managed to sort my bug out, after i changed the fuel pump there was a small issue with the carb. Starts on the first swing now. But need to check the oil proper before i take her for a drive. Keep us updated on your end, hope you come right soon.
Posted: Tue Aug 21, 2018 12:42 pm
by siraaj
hi there,thanks for the info
firstly i have no idea what the woodruff key is
i have taken off my fan belt to see whats going on with the pulleys....i found in spinning the generator pulley,there's a soft grinding noise while spinning
my crank pulley moves in and out ,slightly ...no sideways move...the nuts were tightened properly....so i am clueless
Posted: Tue Aug 21, 2018 12:50 pm
by siraaj
slak wrote: Tue Aug 21, 2018 7:23 am
now i'm more confused.....i had my clutch kit replaced about a month ago....and ever since my bug has had some sinister episodes
siraaj
Posted: Tue Aug 21, 2018 2:07 pm
siraaj wrote: Tue Aug 21, 2018 12:50 pm
siraaj
When a Aircooled motor wears out, the front to back movement on the whole crankshaft increases.
Now when you take the big pulley, in both hands, and pull back then push forward, this is wear movement internally in the motor.
If you jiggil the pulley, and it is loose on the flywheel, then the pulley has excess wear, or the key-way and key ( slot and wedge) that attaches the pulley to the flywheel is worn.
If you pull down on the fan belt and it slides on the pulleys, then its too loose, and needs shim's taken out between the two half's of the top pulley.
Hope this helps
Posted: Tue Aug 21, 2018 2:35 pm
by fig
siraaj wrote: Tue Aug 21, 2018 12:42 pm
This is caused either by the fan rubbing against the fan housing, or worn bearings in the generator/alternator.
Posted: Tue Aug 21, 2018 7:24 pm
by siraaj
retrovan wrote: Tue Aug 21, 2018 2:07 pm
siraaj
Hope this helps
hi Herman
thanks for the feed back...now i know what a woodruff key is.
from what i read in your response is that there is some wear internally....there is definitely no jiggi-jiggi going on my buggy(shes a respectable lady)
hahaa...
i have taken off the generator pulley...only found shims on the side of the nut....the other half had none,so pulley was on its highest point.
i still can't pinpoint if that noise is from the gen pulley or crank pulley....
always appreciate your advice
siraaj
Posted: Tue Aug 21, 2018 7:35 pm
by siraaj
fig wrote: Tue Aug 21, 2018 2:35 pm
hi
i have checked for noises coming from the fan housing,but nothing ....the fact that there is a slight noise coming from the gen pulley,when i spin it, makes sense......but the noise is quite irritatingly loud when the motor runs
