Twin carb to single carb conversion on type 2
mhsmuts
Been thanked: 4 times
Re: Twin carb to single carb conversion on type 2
Post by mhsmuts »
Tony Z wrote:this Is likely what others have spoken about. It works ok in a kombi but it isn’t great. It is simple though.
There are some low profile manifolds that you can get to help either Weber ict’s or idf’s fit below the engine cover, but I think you also need special air filters too. Check out csp and Dellorto.co.uk
You are right this is what they were referring to. But as the guys suggest, first give the twins a good go.
Sent from my SM-G950F using Tapatalk
