Bent drive shafts, is this normal?
fourier
Has thanked: 31 times
Been thanked: 37 times
Re: Bent drive shafts, is this normal?
Post by fourier »
retrovan wrote: Fri May 31, 2019 2:59 pm If I had 3 cents to rub together, I would still bet it is oval drums.
To have 3 cars by the same owner, with the same brake guy, have the same problem, points to drums, not bent shafts.
This is possible but never heard of someone having that problem.
Good luck with your investigation.......
I also think it unlikely that all three your cars have bent axles, and rather suspect distorted or poorly skimmed drums.
Try to trouble shoot...
Lift the rear wheels off the ground. Adjust the brake shoes until they just contact the drum. Turn each drum through a full revolution. If you find a drum that has constant resistance for the full revolution, that drum is probably running true. Now swap the true running drum to another axle, and check again as above. If resistance remains constant, the axle is not bent.
I recently had a well known brake company in Cape Town, skim my Karmann Ghia rear drums. Long story short... drums ended up 0.8mm out of true, and by the time the problem was corrected, the drums were over sized, and turned into paper weights... Not every brake shop can skim these drums properly.
(o= i =o) (o\ ! /o)
german
Has thanked: 11 times
Been thanked: 7 times
Post by german »
Does the drum have play and fit or have the right spicket on the shaft?
John Alves
Been thanked: 48 times
Post by John Alves »
The pulsating has reduced quite a bit since skimming, but not 100%,I will investigate this weekend and report
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
The drums might have a high spot that the drum skimmer wont get out and must be ground down with a pencil grinder and check the ovality of the drums.My 2c worth.
John Alves
Do I remove the dust covers from these wheel bearings? I can't see how gearbox oil can circulate freely to the bearing surfaces
1968 1500 SP Beetle
I normally remove only the one cover being the inside Gearbox facing one.
John Alves
will do
1968 1500 SP Beetle
keithm18@gmail.com
Post by keithm18@gmail.com »
Hi John and all.
I just bought Timken bearings for the rear that look like the attached.
John did you remove one or both of the dust caps and what's the consensus result here?
Thanks guys. Everyday I learn how much I have to learn on this buggy. You gage have forgotten what I still have to learn.. Image
Been thanked: 100 times
Remove the cover facing the gearbox, as suggested above. That way the bearing will keep on being lubricated via the axle tube. The other cover will help the rear hub oil seal in keeping oil from leaking through to the drums.
73type2 wrote: Tue Oct 20, 2020 10:25 pm The other cover will help the rear hub oil seal in keeping oil from leaking through to the drums.
why would you need a secondary means of sealing the axle? If properly installed, the seals should keep the leaks at bay.
You're right, but it wouldn't hurt.
