Ghia fuel sender unit "rubber" seal sweating??
Been thanked: 107 times
Re: Ghia fuel sender unit "rubber" seal sweating??
Post by Haans »
Tony,..thanks. This is really working my guts
Nitrile rubber ? Is this over the counter stuff or is it special?
Bearing man or any suggestion where to start sourcing?
Regards. Haans
Ricoffy
Has thanked: 34 times
Post by Ricoffy »
Haans, I reckon it is normal for the cork seal to swell up a bit. Are you sure you don't have a small fuel leak on a pipe clamp somewhere (maybe around a filter)?
Nick if you go to a spares place such as Alert, or even Midas they sell the thick treated paper gasket sheets looks waxy but chemical and fuel resistant.
Take one or two layers and you should be fine.
Riaan.N
Oil Seal
Been thanked: 38 times
Post by Riaan.N »
Haans, I buy all different kinds of rubber and foam sheets at Sondor. There might be a branch PE with the automotive manufacturers there.
If you don’t come right I can send you piece
Riaan.N wrote: Wed Feb 12, 2020 10:21 am .......rubber and foam sheets at Sondor. ......
If using rubber or foam make sure its fuel resistant and "Closed Cell"
Haans wrote: Tue Feb 11, 2020 8:31 am Hmm,....well. .....only one picture .......
Well here is proof that Haans made it to George ....
:wink:
Nitrile rubber is fuel and oil resistant.
You should be able to get from bearing man or any good engineering supplier
Post by Haans »
Right!....found a piece of the waxy gasket,..too small off to BM this afternoon to see what I can get
Also possible that a bolt or 2 are stripped,.. ut will keep you posted.
Thanks for the pic Herman,..my phone dropped me in Sedgefield. So not much to work on.
He ran like a swiss watch there and back,.....not more than a half a teaspoon under him since I parked it on sunday,....don't know how much oil is in the sump though 🤣😂😱
Haans wrote: Thu Feb 13, 2020 8:11 am ......don't know how much oil is in the sump though 🤣😂😱
May find its become a problem for the grounds man in George...... :shock:
:wink:
