Page 2 of 2
Re: 86 KM TODAY OF NERVES
Posted: Tue Jan 21, 2020 7:15 am
well then at least you have the correct gear ratios for the bus.
Also, Rimula is the best oil to use, thats what I use. I've had it tested before and it does have the correct additives for our engines.
BTW, Retro... Rimula is a diesel oil
You've done a few km now, do a full service, check tappets, timing and change the oil. The worst should be over...
Posted: Tue Jan 21, 2020 8:04 am
by Donovan D
That dipstick saved my engine once.
I also played around with it in a pot of oil on the stove with a thermometer and set it to where I wanted it to go off.
Just check the top of the dipstick from time to time as mine was a bit loose and moved around causing the light to go off.
Posted: Tue Jan 21, 2020 5:23 pm
by Vintage man
My crank pull has a notch on the outer flange and a groove to the right of the notch on the inner , set the timing on the inner groove with a timing light. Dwell is 48.
Any comment on the above.Is that the right timing mark.
Posted: Tue Jan 21, 2020 6:28 pm
the concave "ding" on the pulley (looks like a hammer blow) indicates TDC.
Set Idle to the 7deg mark
I'm not sure how accurate this is but here it is with some measurements
Posted: Wed Jan 22, 2020 6:35 am
by Vintage man
Thanks Tony
Posted: Fri Jan 24, 2020 6:24 pm
by Vintage man
Me again.
Took the bus out for a drive and once warm runs much better.
After lekker drive parked and opened engine lid saw condensation on bottom of carb and carb very cold. Is that normal.
Posted: Sun Jan 26, 2020 3:11 pm
normal, nothing to worry about
it is fuel evaporating in the manifold, causing the area around it to get cold - humid air will condense on this
Posted: Mon Jan 27, 2020 8:02 am
by Vintage man
Really appreciate all the advise.
