Page 2 of 3
Posted: Wed Sep 05, 2007 3:13 pm
by Merlin
Dave Rowley is supplying mine, and we had a long chat over my engine, etc. so 'm going with his knowledge...a blown alternator is going to make me a very unhappy man.
My engine will top out around 5,300.
N.
Posted: Wed Sep 05, 2007 3:42 pm
by Bugger
So Why The huff and Puff and I`ll blow your hous down If you know what you want
End of the day
It depends on the suplier if it `s going to last or not
Posted: Wed Sep 05, 2007 4:02 pm
by Merlin
No issues my side.
Just curious to find out more and drop my comments about the system.
N.
Posted: Wed Sep 05, 2007 4:56 pm
MTM, the fan is geared by the fact that the crank and alternator pulleys are different sizes.
Not 100% on this, but I have heard that the flat serpentine pulley actually adds more friction to the setup, therbey requiring more power to turn. It was designed for the bug as the high revving boys were throwing their fan belts off regularly due to its momentum going over the top pulley. That is why the tensioner pushes the belt in under the top pulley. I have also heard that at high speeds, it adds a fair bit of force to the alternator bearings as its not slipping and eventually kills the bearings as they are now seeing more force than they were designed for.
The advantage of these belts (and why they are popular on modern vehicles) is that they dont slip and they are extremely flexible, being also able to transmit power on both sides (toothed and flat side).
Posted: Wed Sep 05, 2007 6:40 pm
by Merlin
Tony Z wrote:MTM, the fan is geared by the fact that the crank and alternator pulleys are different sizes.
Learn something new everyday.
Tony Z wrote:Not 100% on this, but I have heard that the flat serpentine pulley actually adds more friction to the setup, therbey requiring more power to turn.
Tony Z wrote:The advantage of these belts (and why they are popular on modern vehicles) is that they dont slip and they are extremely flexible, being also able to transmit power on both sides (toothed and flat side).
Take away power, or generate power?
Tony Z wrote:I have also heard that at high speeds, it adds a fair bit of force to the alternator bearings as its not slipping and eventually kills the bearings as they are now seeing more force than they were designed for.
So I keep hearing...
I hear that the tension is not that great, so does it really add
that much more wear?
How often, from what you know, before replacement is necessary, and can a layman do it?
Posted: Wed Sep 05, 2007 6:55 pm
it takes more power to turn... therefore it uses power (not much but it does).
Q: how can the kit generate power?
Its got a tensioner and the belt is longer than it needs to be... a 3 year old can thumb suck his way around a belt change with this system
Posted: Wed Sep 05, 2007 7:39 pm
by IMPI
Personally the only serpentine belt experience I have is on my waterpumpers but they last a long time 300000km is common. Most aftermarket and even vw old school belts are shitty.
I vote go for it
A
Posted: Wed Sep 05, 2007 7:42 pm
by SUZIE
Okay oaky I know i am a vannermerwe Bugger, but i was looking at my aircooled engine today and was wondering how do you tension the van belt? and how do you replace it?
Posted: Wed Sep 05, 2007 7:54 pm
by Bugger
OK SORRY
I`ll Love that nerve alone now
By adding or removing shimms between the 2 pullys when you remove shims you put them on the outside of the front one then tighten the nut
Posted: Wed Sep 05, 2007 7:57 pm
by SUZIE
No problem, i have no heart, no feeling " vannermerwe stop crying" he he he he
by remopving these shims, is it alingning the pullys or tensioning the belt?
Posted: Wed Sep 05, 2007 8:05 pm
by Bugger
"BOTH"
Posted: Wed Sep 05, 2007 8:13 pm
by SUZIE
Bugger , you bussy makeing me scratching my head, I wil have a look at it, but not tomorow, maybe by the weekend or next weekend, but realy thanks for the info, will mostdefnetly try it
Posted: Wed Sep 05, 2007 8:14 pm
by SUZIE
Bugger - did you get your PM?
Posted: Thu Sep 06, 2007 7:50 am
by Merlin
First off Suzie, get the correct size belt...then by adding or removing shims you're 'pushing' or 'pulling' the belt down...note the angle on the inside of the pulley... \/ ...makes the belt ride higher or lower.
Posted: Thu Sep 06, 2007 5:39 pm
by Bugger
SUZIE wrote:Bugger - did you get your PM?
no
