Sanding
acid baths are usually easy to find, just not in the size big enough to do a chassis....
for the wet sand blasting idea, you can always add a soluble oil to the water to prevent rust....... then wash the area when you are ready to paint, allow to dry and primer it
The 80 grit seems to work quite well
Tried last night, by hand
Gives you a workout. I will be having bulging biceps after this project is done
I have a Black and Decker sander here; I'm sure that it would make the task much easier
Today after work, will be in the garage until dark working on the chassis
have you tried one of these yet??? it spins at 8500rpm on an angle grinder. its q uite relentless and nothing stands in its way!!! go get one at your local builders warehouse!!!
the pic comes from this site which has a fantastic write-up of a full bug rebuild.
http://www.cirkut.com/bug/week4.html
Sand blasting or wet blasting is the easiest way to do it.
I've used those wire cup wheels that fit on an angle grinder and while they work well removing paint they're nearly useless on removing rust or mill scale.
In order to prevent the bare steel from tarnishing quickly you can mix 5% ammonia by volume into the water. The ammonia will have no effect on the Duram NS4 primer.
- Drive Train
If you are going to use one of those wire wheels on the angle grinder, make sure that you wear a FULL face mask/shield(almost like a welder's helmet). Those wires DO COME OFF..... ask me how I know!?
While taking paint off and dealing with light rust, it is absolutely USELESS against stuff like Durabak(sp?) or those rubber coatings. All it does is 'melt' the rubber and move it around...... ask me how I know!?
VW Enthusiast
