Page 2 of 2
Posted: Tue Mar 21, 2006 9:23 am
double check that your cooling tin is all in place and that it effectively keeps the hot air on the bottom half of the engine.
Posted: Tue Mar 21, 2006 2:40 pm
by eben
because its non stock engine the cooling tin doesn't seperate the top from the bottom effectively... While the rubber boot and flange ensures the cooling fan draws in cool air, the carbs draw in the hotter air from around the engine...
Posted: Tue Mar 21, 2006 5:30 pm
sheet metal... I know its not easy, but anything you can do will help.
Posted: Wed Mar 22, 2006 9:31 am
by calooker
The engine compartment on a T3 does not seal the way the T1 does, it doesn't even have a rubber "seal" it will not help trying to seal the top half from the bottom.
Posted: Wed Mar 22, 2006 9:36 am
by calooker
I have that Alfa air-box, I was going to take pics this morning but I got side tracked and didn't do it, I will take the pics later today, sorry, I think it will work for you.
Posted: Wed Mar 22, 2006 10:14 am
by eben
thanks rui,
Yes Tony you have to remember that the Type 3's come out with both cooling-fan and carburettor fresh air intakes that mount on the body so they didn't need to be sealed between top and bottom.
Tell me rui, is this the filter you are talking about?
Posted: Wed Mar 22, 2006 10:16 am
by flatfourfan
looks hawt.........I actually had two of the upper intake sections on my old dells that I sold to Rui........I may still have them lying around somewhere.......
Posted: Wed Mar 22, 2006 10:19 am
by eben
I cant use those cast carb tops though... they seem too high..
Posted: Wed Mar 22, 2006 10:20 am
love those alfa engines.... 1680cc, 9000rpm no problems... friend of mine has one, what a little screamer that is...
*sniff sniff, dreaming of home again*
Posted: Wed Mar 22, 2006 10:27 am
by flatfourfan
yup, was thinking the same, in a type 2 or 1 you may get away with it............I must admit, they look the tits.........lol.Very porsche like, begging for a carb turbo set up.
Posted: Wed Mar 22, 2006 10:29 am
by eben
i had a 1500 lying in the garage for about 2years to transplant but not as much a drop-in conversion... the engine is quite high too....
Posted: Thu Mar 23, 2006 12:17 pm
by eben
Now that I've been looking at those pictures of the box you sent me rui I dont think that it would work. I need smaller rounder inlets to the box and a round connection to the body as well. Even one round inlet and one round body connection would work. Doesn't some opel (AFM injection) and digifant golf boxes work like that? One round inlet on the AFM meter, throttle body side and a round connection on the airbox where the air goes in? I'll have to go to a scrapyard and have a look at the options. Thank you for the photos by the way Rui.
