Page 2 of 2
Posted: Wed May 31, 2006 10:20 am
by Merlin
Kewl; thanks.
I'll get it checked it out asap.
I live in a valley with a river running through it, so it's get slightly arctic here in the mornings. :/
N.
Posted: Wed May 31, 2006 10:34 am
by calooker
If the choke remains activated longer than it should it will also be heavier on the fuel consumption, and drive crap, no power and puff out a little black smoke from the exhaust, as the mixture is much richer than it needs to be after warm up. I can't remember the direction in which to turn the choke at the moment to set it 100%, but I will check tonight, I will let you know. It is simple job in your case only 2 screws need to be loosened, where I pointed out to you that you had a stripped screw/thread.
Posted: Wed May 31, 2006 10:43 am
by Merlin
A'right - I remember that. :)
Well, duly noted that I drive my bug hard but I've put in over R 400 fuel in the last 5 days, and I don't think I did that much mileage. :shock:
N.
