Vacuum port for distributor advance normally only comes from one carb.Wanted to use both,for better signal. Carefully drilled the other carb for a similar port. Then used a T junction to combine the two.
Here is a picture of the most recent aircleaners with the longer pipe that passes through the element to the extended top for longer velocity stack. This richens the mixture at full load,when the intake pulses are strong. Makes a HUGE difference.
The engine is now 1423 cc's. Bore 77mm, stroke 76.4mm.
Used an Oettinger/OKRASA crankshaft that was made for the wasserboxer. Actually found an 82mm one long ago for R1000, when a standard crank with counterweights welded on would cost R1500. (Early nineties). Then exchanged it for the 76.4mm one at that wbx place in Kemton Park. Made from chrome-moly i think, the bearing surfaces are very hard. McDonald engineering polished and fitted it to my AS21-casing.
Dont know what difference the harder bearing surface makes to friction,but even if it is half of a percent,everything adds up.
Assembled the engine myself. Was the first engine i opened.Had a special camshaft made, with less overlap.
